Veho VEP-008-Z8 360 Designer headphones with flex cable
Quicklinx: BNJSWS00 Mfr#: VEP-008-Z8
The headphones come with built-in noise isolating technology, soft leather ear pads and a contemporary aluminum look, designed to stand out from the others.
The Z8 headphones are fully compatible with all devices such as MP3 players, iPhone, iPad, laptops or any device which uses a standard 3.5mm output jack. Alternatively, connect it up to the SAEM S4 to turn them into wireless Bluetooth headphones.
The 40mm noise isolating technology will decrease the surrounding noise pollution to allow you to enjoy and listen to your music the way you want. The super soft leather ear pads are designed for your comfort and the adjustable headband makes these headphones ideal for any head size.
The foldable sleek and stylish design comes with a detachable 130cm flex flat 'anti' tangle cable that can be easily stored in the protective carry case, perfect for traveling or commuting.
Veho Z8 - headphones
Headphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
Headphones Form Factor
Full size
Foldable
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 92 dB
Impedance
32 Ohm
Noise Isolating
Recommended Use
Audio Output
Full size
Foldable
Wired
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
92 dB
Impedance
32 Ohm
Diaphragm
40 mm
Connector Type
Headphones (mini-phone 3.5mm)
Cable
Detachable Cable
Carrying case
Cable Details
Headphones cable - 1.3 m
