Pioneer DDJ-FLX2 Controller
Quicklinx: J4SMWS00 Mfr#: DDJ-FLX2
10 In Stock
£124.17 ex VAT
£149.00 inc VAT
Works with various DJ applications
The DDJ-FLX2 works with a number of DJ applications, including rekordbox and djay – popular choices among both beginners and professionals. After installing your preferred app on your mobile device, you can connect to the controller and start DJing right away. If you want to challenge yourself to learn more advanced techniques, you can use DJ software, such as Serato DJ Lite, on your PC/Mac.
Supports music streaming services
You can DJ with tracks from music streaming services to suit the the music and DJ style you want to play. The DDJ-FLX2 supports Beatport Streaming, Beatsource Streaming, SoundCloud Go+/DJ, and TIDAL. If you use the djay software/app, you can access Apple Music too. *Please note that the available music streaming services may vary depending on your DJ application and geographical location.
Compatible music streaming services
Apple Music, Beatport Streaming, Beatsource Streaming, SoundCloud Go+/DJ, TIDAL
Easy on your smartphone, professional on your PC/Mac You can DJ with your favorite device, whether that’s a smartphone, tablet, or PC/Mac. You don't need to buy a new device just for DJing.
Mix support functions It’s easy to replicate the seamless song mixing of professional DJs thanks to the Smart CFX* and Smart Fader* features on the DDJ-FLX2. Smart CFX, used with the Performance Pads, enables you to recreate complex and dynamic effect techniques. Smart Fader automatically optimizes control of the volume, BPM, and bass, so you can perform perfect mixes with by simply sliding the crossfader.
*Function names and operations may vary depending on your DJ application.
  • Audio clarity
    The AlphaTheta DDJ-FLX2 boasts a total harmonic distortion of 0.006%, ensuring that the sound produced is clear and high-quality, making it ideal for DJs who value audio fidelity.
  • Control options
    Equipped with knobs, faders, jog wheels, trigger pads, and rotary encoders, this controller provides a set of controls that cater to various mixing styles and techniques.
  • Connectivity
    The integration of USB and Bluetooth connections enables DJs to easily link devices, facilitating a wider range of performance possibilities.
  • Portable design
    Being USB bus powered, this DJ controller can be used anywhere, making it a great choice for mobile DJs who value convenience and efficiency.
  • Security features
    The built-in Kensington security slot allows users to secure their equipment, providing an extra layer of protection while performing or transporting the unit.
AlphaTheta DDJ-FLX2 DJ controller
Brand: Pioneer
