Sony Sony SRG-XB25 - Conference camera
Quicklinx: H8P0WS00 Mfr#: SRG-XB25B
The SRG-XB25 high-zoom BOX camera draws on decades of Sony's professional imaging know-how to suit a wide range of content creation applications. It's ideal for capturing and streaming impressive 4K pictures in environments including seminar rooms, lecture theaters, virtual production studios, government/parliament buildings and houses of worship. The cost-effective SRG-XB25 is particularly appealing for multi-camera shooting setups, where high-quality images are required without the need for a team of dedicated camera operators. The integrated lens with powerful 25x optical zoom captures frame-filling close-ups of speakers and presenters, even when the camera's installed at the back or larger auditoriums and public venues. The SRG-XB25 fits seamlessly into all-IP production environments, with a single Ethernet cable carrying power, streaming video and camera control signals.
  • Robust, stylish and compact
    Compact and lightweight SRG-XB25 can be readily integrated into any environment. Rear panel guards assure extra robustness, and the large, easy-to-read tally lamp is useful in multiple-camera setups.
  • Powerful 25x optical zoom
    The integrated autofocus lens with 25x optical zoom plus additional digital zoom assures ultra-clear, powerful close-ups of presenters or audience members.
  • Easy IP connectivity, single-cable installation
    Camera control, PoE and streaming video output are carried over a single Ethernet cable, reducing installation costs and simplifying integration in space-restricted or hard-to-reach locations.
  • High-quality 4K 60p images
    The camera's 1/2.5-type Exmor R CMOS sensor captures smooth, crisply detailed 4K 60p video with excellent low-light sensitivity.
  • Broadcast-style tally light
    The camera-mounted tally light gives visual confirmation to the lecturer or presenter when the camera is active. The horizontal-bar-style light is easily visible to both performer/presenter and director.
  • Audio input
    Connect an external microphone or line-level source to capture clear pictures with sound in lecture theaters and meeting rooms or on reality TV shows.
Sony SRG-XB25 - conference camera
Conference camera - fixed
Audio
Camera Mount Type
Wall mount, ceiling mount, tripod mount
866 g
Wired
Camera
Optical Zoom
25 x
Max Resolution
3840 x 2160
Frame Rate (max)
60 frames per second
Video Modes
3840p, 1080p, 720p, 480p
Optical Sensor Type
Exmor R CMOS - 1/2.5" - 8.5 MP
Minimum Illumination
1 lux F1.6 - 50 IRE
Focal Length Control
Motorized zoom
Focal Length
0.48 mm - 12 mm
HDMI
Control Interface
VISCA
Voltage
DC 12 V / PoE
ONVIF (Profile S) support, Webcam Support (UVC)
Conference camera
Audio Support
Audio Formats
AAC, MPEG TS
Camera Mount Type
Wired
866 g
Camera
Colour - fixed
Digital Video Format
H.265, H.264
Max Digital Video Resolution
3840 x 2160
Video Modes
Digital Zoom
4
Exposure Range
1 sec - 1/10000 sec
1 lux F1.6 - 50 IRE
Digital Video Capture Resolution
3840 x 2160
Frame Rate (max)
Image Sensor
8.5 MP Exmor R CMOS 1/2.5"
Lens Construction
Motorized zoom
Optical Zoom
25 x
Focal Length
0.48 mm - 12 mm
Horizontal Field of View (degree)
68
Video
HDMI
Network Protocols
RTMP, RTSP, NDI HX, CGI
Control Interface
VISCA
Ports
HDMI output , LAN/power - RJ-45 , Audio line out , Audio line in , VISCA input , VISCA output
IEEE 802.3af
Power Requirements
DC 12 V / PoE
