Record high quality stereo sounds with the new MUVI K-Series external microphone from Veho.
The extra-long 2m cable is long enough to ensure that you can mount the microphone in as many different positions as possible, and the handy crocodile clip included means that the microphone can be mounted easily on clothes or outdoor gear or in car if you want to capture higher quality sound when your K series is mounted in the case or in windy conditions.
The MUVI K-Series external microphone also comes with a screw cap that secures to the external cap of the K-Series waterproof case to ensure that the microphone stays in place when the camera is in the protective housing.
The protective cover on the microphone helps reduce wind noise and distortion, so you will only hear the sound that you want.
- Veho - microphone
- Product Type
- Microphone
- Recommended Use
- Camera
- Designed For
- Muvi K-Series K-1, K-Series K-2
- Product Type
- Microphone
- 46 g
- Recommended Use
- Camera
Microphone
- Connectivity Technology
- Wired
- Connector Type
- Microphone
- Included Accessories
- Clothing clip, microphone cover, screw cap
- Cable Details
- Microphone cable - coiled - 2 m
- Designed For
- Veho muvi K-Series K-1, K-Series K-2
