Available with 48 RJ45 Gigabit ports, the UniFi Switch delivers robust performance, PoE+ support, and intelligent switching for growing networks.
Advanced port management
Each switch port offers custom settings: port name, PoE, network/VLAN configuration, and operation mode (switching, mirroring, or aggregate). -
Optical fiber connectivity
Two SFP ports support uplinks of up to 1 Gbps. For high-capacity uplinks, each 48-port model includes two SFP+ ports for uplinks of up to 10 Gbps. -
Convenient PoE+ support
The UniFi Switch features auto-sensing IEEE 802.3 af/at and 24 V passive PoE to power multiple devices on the network. -
Seamless integration
The UniFi Switch integrates seamlessly into the UniFi Software-Defined Networking (SDN) platform to create a highly scalable, end-to-end system of network devices across multiple locations - all controlled from a single interface.
- Ubiquiti UniFi Switch US-48-750W - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 2 x 10 Gigabit SFP+ + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Non-blocking switching capacity: 70 Gbps , Switching capacity: 140 Gbps , Forwarding performance: 104.16 Mpps
- Remote Management Protocol
- HTTP
- Non blocking ports
- IEEE 802.3af, IEEE 802.3at
- Power
- AC 120/230 V (50 - 60 Hz)
- 48.504 cm x 34.76 cm x 4.445 cm
- 5.3 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- HTTP
- Status Indicators
- Port transmission speed, PoE, link/activity
- 48 x 1000Base-T RJ-45 PoE+ - 34.2 W , 2 x 1000Base-X SFP , 2 x 10GBase-X SFP+ , 1 x console RJ-45
- Power Device
- Internal power supply
- Power Provided
- 750 Watt
- Voltage Required
- IC, FCC, RoHS, WEEE, ETSI 300 019
- 48.504 cm
- 34.76 cm
- 4.445 cm
- 5.3 kg
- -5 °C
- 40 °C
- 5 - 95% (non-condensing)
