Ubiquiti EdgeSwitch 48 Port Switch Managed 48x 10/100/1000 (PoE+) Rack-Mountable
Quicklinx: BXWTWS00 Mfr#: ES-48-500W
Type: 10 Gigabit Ethernet
Managed: Yes
POE: PoE+
£663.67 ex VAT
£796.40 inc VAT
  • Non-Blocking Throughput Switching Performance
  • Gigabit Ethernet RJ45 and SFP+/SFP Ports
  • Auto-Sensing IEEE 802.3af/at PoE
Advanced Switching Technology for the Masses
Build and expand your network with Ubiquiti Networks® EdgeSwitch™, part of the EdgeMAX® line of products. The EdgeSwitch is a fully managed, PoE+ Gigabit switch, delivering robust performance and intelligent switching for growing networks.
The EdgeSwitch offers an extensive suite of advanced Layer-2 switching features and protocols, and also provides Layer-3 routing capability.
The EdgeSwitch offers the forwarding capacity to simultaneously process traffic on all ports at line rate without any packet loss.
For its total, non-blocking throughput, the 24-port models support up to 26 Gbps, while the 48-port models support up to 70 Gbps.
PoE+ Flexibility
The EdgeSwitch models are available with 24 or 48 PoE Gigabit Ethernet ports of auto-sensing IEEE 802.3af/at or configurable 24V Passive PoE to simplify your infrastructure.
By default, the EdgeSwitch automatically detects 802.3af/at devices so they automatically receive PoE. For 24V Passive PoE devices, manually enable 24V passive PoE using the EdgeSwitch Configuration Interface.
Fiber Connectivity
The EdgeSwitch provides fiber connectivity options for your growing networks. The 24-port models include two SFP ports, providing up to 1 Gbps uplinks.
For high-capacity uplinks, the 48-port models include two SFP and two SFP+ ports, providing up to 10 Gbps uplinks.
Comprehensive User Interface
Designed for convenient management, the EdgeSwitch Configuration Interface allows administrators to configure and monitor switch features in a graphical user interface.
For advanced users, an industry-standard command-line interface (CLI) is available through telnet and SSH.
Powerful Functionality
The EdgeSwitch uses a sophisticated operating system that provides basic switching features, PoE configuration per port, and a variety of advanced features including:
  • MSTP/RSTP/STP
  • VLAN, Private VLAN, Voice VLAN
  • Link Aggregation
  • DHCP Snooping, IGMP Snooping
  • TACACS+, RADIUS, 802.1X, MAC Filtering, ACL
  • DiffServ, CoS
  • Static Routing, Policy-Based Routing
  • Powerful enterprise switch models
    The EdgeSwitch delivers the forwarding capacity to simultaneously process traffic on all ports at line rate without any packet loss.
  • Enterprise-class features
    The EdgeSwitch supports an extensive suite of advanced Layer-2 switching features and protocols, and also provides Layer-3 routing capability.
  • Optical fiber backhaul
    Two SFP ports support uplinks of up to 1 Gbps. For high-capacity uplinks, each 48-port model includes two SFP+ ports for uplinks of up to 10 Gbps.
  • Convenient PoE+ support
    The EdgeSwitch features auto-sensing IEEE 802.3af/at and 24V passive PoE to power multiple devices on the network.
  • Breakthrough value
    The EdgeSwitch provides top price/performance value: a full-featured, enterprise-class switch.
  • Advanced UI
    The comprehensive UI is easy to learn and allows administrators to configure and monitor features in a graphical user interface. For advanced users, a Command-Line Interface (CLI) is available through telnet and SSH.
Ubiquiti EdgeSwitch 48 - switch - Managed - rack-mountable
Switch - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x Gigabit SFP / 10 Gigabit SFP+ + 2 x SFP
Power Over Ethernet (PoE)
PoE+
Performance
Non-blocking switching capacity: 70 Gbps
VLAN support, STP support, RSTP support, Jumbo Frames support, 24KV ESD Protector
IEEE 802.3af, IEEE 802.3at
AC 120/230 V (50 - 60 Hz)
48.1 cm x 34.8 cm x 4.45 cm
5.3 kg
Switch - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
PoE+
Performance
Status Indicators
Port status, port transmission speed, PoE, link/activity
48 x 1000Base-T RJ-45 PoE+ , 2 x SFP+ , 2 x SFP
Internal power supply
500 watt
FCC
48.1 cm
34.8 cm
4.45 cm
5.3 kg
-5 °C
5 - 95% (non-condensing)
Managed: Yes
POE: PoE+
Brand: Ubiquiti
Price Range Ex VAT: £500 - £750
