The UniFi Switch delivers robust performance, PoE+ support, and intelligent switching for growing networks.
Powerful enterprise switch
The UniFi Switch delivers the forwarding capacity to simultaneously process traffic on all ports at line rate without any packet loss. -
Advanced port management
The switch port offers custom settings: port name, PoE, network / VLAN configuration, and operation mode (switching, mirroring, or aggregate). -
Convenient PoE+ support
The UniFi Switch features auto-sensing IEEE 802.3af/at and 24V passive PoE to power multiple devices on the network.
- Ubiquiti UniFi Switch US-24-250W - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Non-blocking switching capacity: 26 Gbps , Switching capacity: 52 Gbps , Forwarding performance: 38.69 Mpps
- Remote Management Protocol
- HTTP
- IEEE 802.3af, IEEE 802.3at
- Power
- AC 120/230 V (50 - 60 Hz)
- 48.5 cm x 28.54 cm x 4.37 cm
- 4.7 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- HTTP
- Status Indicators
- Port transmission speed, PoE, link/activity
- 24 x 1000Base-T RJ-45 PoE+ - 34.2 W , 2 x 1000Base-X SFP , 1 x console RJ-45
- Power Device
- Internal power supply
- Power Provided
- 250 watt
- Voltage Required
- IC, FCC, RoHS, WEEE
- 48.5 cm
- 28.54 cm
- 4.37 cm
- 4.7 kg
- -5 °C
- 40 °C
- 5 - 95% (non-condensing)
