External USB sound system coems with true 5.1 audio channels for amazing surround sound.
- Trust Sound Expert 510EX - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB
- 11.6 cm x 9.8 cm x 2.4 cm
- Sound Output Mode
- 5.1 channel surround
- DAC Resolution
- 16-bit
- Sample Rate
- 48 kHz (max)
- Hardware Controls And Indicators
- Mute button
- System Requirements
- Microsoft Windows 98SE/2000/ME/XP
- 2-year warranty
- Sound card
- Form Factor
- External
- Interface Type
- USB
- 11.6 cm
- 9.8 cm
- 2.4 cm
Audio Output
- Sound Output Mode
- DAC Resolution
- 16-bit
- Sample Rate
- 48 kHz (max)
- Mute button
- DirectSound3D, EAX 2.0, A3D, DirectX
- 1 x microphone - mini-phone 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x speakers (centre/subwoofer) - mini-phone stereo 3.5 mm , 1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Software
- Drivers & Utilities
- OS Required
- Additional Requirements
- CD-ROM
- System Requirements Details
- Windows 98SE/2000/ME/XP - RAM 64 MB - HD 25 MB
- Limited warranty - 2 years
Customer reviews
Write a review for the Trust 5.1 External Surround Sound Card SC-5500p here!
Excellent for the price
Reviewed by Dylan Brandes. Review Posted 20/12/2006
Having just bought a laptop and also owning a creative 5.1 surround sound system i needed this to get both connected together. Really great for the price which is also about 10 pounds cheaper that ebuyer. Sound quality is great, and this unit is self powered by the USB connection. All in all a great purchase. Thanks DABS
Overall
Ease of use
Value for money
Easy to set up.
Reviewed by Antbert. Review Posted 23/01/2007
I've got an Creative 5.1 surround sound system that has been sitting gathering dust because I had to move to a laptop. The unit comes with comprehensive and easy to follow instuctions. My speakers were already in place and so 15 minutes is all it took to set up. I would recommend this product immensely!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
