Creative Sound Blaster Audigy Rx PCI-Express Sound Card
Quicklinx: 8Z71WS00 Mfr#: 70SB155000001
Interface: PCI Express x1
Sound Output Mode: 7.1 channel surround
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£45.49 ex VAT
£54.58 inc VAT
The Sound Blaster Audigy Rx is an advanced sound card that represents the perfect upgrade from basic motherboard audio to immersive cinematic surround sound. With its advanced chipset designed to process the legendary EAX reverb engine, you can look forward to experiencing superb 7.1 multi-channel audio. It also features an SNR of 106 dB and the Sound Blaster Audigy Rx Control Panel.
  • E-MU chipset for advanced effects processing
    Sound Blaster Audigy Rx features the Creative E-MU chipset, which was designed to process the legendary reverb engine EAX (Environmental Audio eXtensions) and deliver amazing cinematic audio playback effects without having to bog down your CPU. This ensures you get great quality effects and audio without affecting your computer's processing power.
  • Dual microphone inputs
    The sound card has two microphone inputs to allow you to grab a friend to sing simultaneously! Or, use the second input to record the music accompaniment while you sing. The possibilities are endless!
  • Super low-latency audio recordings
    Enjoy reduced latency with the support of audio stream input/output (ASIO) drivers, making Sound Blaster Audigy RX the perfect solution for high-quality, low-latency audio recordings.
  • Control and customize your audio
    Sound Blaster Audigy Rx Control Panel is a dedicated PC application that lets you control and customize every aspect of your sound card. You can adjust your creative multi speaker surround (CMSS or CMSS 3D) settings to upmix stereo content to your multi-channel speaker system and add acoustic depth to your multi-channel content. Or, use Mic Monitoring and Stereo Mixing to hear yourself while you record and so that you can hear the effects instantly.
  • Premium Sound Blaster quality
    Enjoy premium Sound Blaster audio quality over and above basic motherboard audio with a Signal-to-Noise Ratio (SNR) of 106 dB. Plus, Stereo Direct lets you listen to your music pure and unprocessed at the amazing bit rate of 24-bit 192 kHz.
  • Dedicated high-quality headphone amp
    With the 600-ohm headphone amplifier, the Sound Blaster Audigy Rx is able to drive the most demanding of studio headphones.
  • Enjoy cinematic surround sound
    The Sound Blaster Audigy Rx also lets you enjoy a truly cinematic experience, supporting up to 7.1 multi-channel speaker output. It gives you an immersive, cinematic audio experience for your movies, games and more!
Creative Sound Blaster Audigy RX - sound card
Sound card
Enclosure Type
Internal
Interface Type
PCI Express x1
Signal Processor
Creative E-MU
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
192 kHz (max)
Signal-To-Noise Ratio
106 dB
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
1-year warranty
Sound card
Internal
Interface Type
PCI Express x1
Processor / Memory
Signal Processor
Creative E-MU
Audio Output
Sound Output Mode
DAC Resolution
24-bit
Sample Rate
192 kHz (max)
106 dB
ASIO 2.0, EAX 4.0, OpenAL
Audio Modes
Record: 24-bit 96 kHz , Playback: 24-bit 192 kHz stereo - 106 dB , Playback: 24-bit 96 kHz 7.1 - 106 dB
1 x speakers (front surround) - mini-phone 3.5 mm , 1 x speakers (rear/right surround) - mini-phone 3.5 mm , 1 x speakers (centre/subwoofer/left surround) - mini-phone 3.5 mm , 2 x microphone - mini-phone 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x SPDIF output - TOSLINK
Software
Drivers & Utilities, Creative Wavestudio, Creative Diagnostic, Creative Smart Recorder, Creative Karaoke Player, Creative System Information, Creative Rx Control Panel, Creative EAX Studio
System Requirements Details
Windows XP - Core 2 Duo - 2 GHz - RAM 1 GB - HD 600 MB
Limited warranty - 1 year
Resources
The following resources are available for the Creative Sound Blaster Audigy Rx PCI-Express Sound Card
Brand: Creative
Stock Status: While stocks last
Stock Status: Clearance
