TRENDnet Wireless AC Easy-Upgrader
Quicklinx: B4D1WS00 Mfr#: TEW-820AP
  • IEEE 802.11n
TRENDnet's Wireless AC Easy-Upgrader, Model TEW-820AP, adds a Wireless AC network to a wireless or wired router. Simply plug the TEW-820AP into an available Ethernet port on the back of your existing router--and you're done. For your convenience the Wireless AC network is setup and pre-encrypted out of the box.
Easy Setup
Install the upgrader in minutes with a quick guided setup wizard
One Touch Connection
Securely connect Wireless AC enabled devices to the TEW-820AP at the touch of the Wi-Fi Protected Setup (WPS) button
Encrypted Wireless
For your convenience the Wireless AC network is pre-encrypted with its own unique password
Next Generation Wireless AC
Wireless AC provides uninterrupted HD video streaming in a busy connected home. You need a Wireless AC enabled device in order to connect to the TEW-820AP
Compact
The compact form factor easily fits next to your existing router
TRENDnet TEW-820AP - bridge - Wi-Fi 5 - desktop
Bridge
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Maximum number of configured SSIDs: 4
Network / Transport Protocol
DHCP, CSMA/CA
MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Access Point+, Wi-Fi Protected Setup (WPS), reset button, Wireless Client Mode
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
6.5 cm x 6.7 cm x 2.1 cm
48 g
3-year warranty
Bridge
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Selectable Channels Qty
165
DHCP, CSMA/CA
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 5 pin Micro-USB Type B (power only)
Aerial
Aerial
Internal
Antenna Qty
1
Gain Level
3 dBi
External power adapter
2.3 Watt
6.5 cm
6.7 cm
2.1 cm
48 g
Limited warranty - 3 years
0 - 95% (non-condensing)
