TRENDnet TEW-815DAP AC1750 Dual Band Wireless Access Point
Quicklinx: 9Q63WS00 Mfr#: TEW-815DAP
  • IEEE 802.11n
TRENDnet's high performance AC1750 Dual Band Wireless Access Point, model TEW-815DAP, supports Access Point (AP), client, repeater, Wireless Distribution System (WDS) bridge, and WDS + AP modes. The TEW-815DAP generates concurrent 1.3 Gbps wireless AC and 450 Mbps wireless N networks. Embedded GREENnet technology reduces power consumption by up to 50%.
Multi-Mode Support
Supports Access Point (AP), Client, Repeater, Wireless Distribution System (WDS), and WDS + AP modes
One Touch Connection
Securely connect to the access point at the touch of the Wi-Fi Protected Setup (WPS) button
Multi Language
Multi Language Interface: English, Spanish, French, German, and Russian
Logs
Real time logs and statistics help trouble shooting
Encrypted Wireless
Support for wireless encryption up to WPA2
Multiple SSIDs
Create up to four SSIDs per wireless band
Next Generation Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected environment
Simultaneous Dual Band
High performance 1.3 Gbps Wireless AC + 450 Mbps Wireless N bands
Wireless Coverage
Extended wireless coverage with MIMO antenna technology
Compatibility
Compatible with legacy wireless devices
Gigabit Port
Gigabit LAN port maintains high performance connections to the wired network
Energy Savings
IPv6
IPv6 network support
Targeted Beamforming
Increased real-time performance by directing stronger wireless signals to your specific location
For maximum performance of up to 1.3 Gbps use with a 1.3 Gbps 802.11ac wireless client
Maximum wireless signal rates are referenced from IEEE 802.11 theoretical specifications. Actual data throughput and coverage will vary depending on interference, network traffic, building materials and other conditions
Brand
TRENDnet
Radio access point
Networking / Connectivity Technology
Wireless
Networking / Form Factor
External
Header / Model
Speed
1.3 Gbps
Compatibility
Mac, PC
Miscellaneous / Encryption Algorithm
WEP, WPA-PSK, WPA2-PSK
Protocol
IEEE 802.11a, IEEE 802.11ac (draft 2.0), IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Networking / Network / Transport Protocol
DHCPv6, DHCP, TCP/IP
Dimensions & Weight / Height
4.8 cm
Dimensions & Weight / Weight
340 g
Dimensions & Weight / Depth
18 cm
Dimensions & Weight / Width
15.5 cm
Header / Packaged Quantity
1
Service & Support / Type
3 years warranty
