TRENDnet TC-NT3 VDV & USB Cable Tester
Quicklinx: B3Y0WS00 Mfr#: TC-NT3
TRENDnet's VDV & USB cable tester, model TC-NT3, is a comprehensive cable tester for network professionals. It accurately tests a variety of voice, data, video, and USB cables. The TC-NT3 identifies proper, severed, short circuit, and cross connected pins for cable distances of up to 300 meters.
Quick test mode issues a pass/fail for large test batches.
All components fit into a convenient travel case.
  • TX/RX troubleshooting
    Displays separate TX and RX results for more efficient troubleshooting.
  • Local and remote testing
    A master unit facilitates loop testing and a detachable remote terminal unit allows for cable testing in locations away from the master unit.
  • Continuous scan
    Continuous scan mode is design to accommodate testing with cable ends in different locations.
  • Manual scan
    Manual scan is well suited for loop back cable testing.
  • Quick test mode
    Designed to quickly test large cable quantities, quick test mode identifies a given cable type and then immediately issues a pass/fail for the same cable type.
  • Blinking hub/switch mode
    Designed to confirm which port on a hub/switch a given cable is networked to, blinking hub/switch mode causes the connected network port's LED indicator to blink.
TRENDnet TC-NT3 - network tester
Network tester
Cable Types
CAT3, CAT4, CAT5, CAT5e, coax, CATV, CAT6, CAT6a, CAT6e, CAT7, CAT8, CAT3e
Tests, Tools and Measurements
Tests for crossed wires, short circuit, grounding
Cable tone generator
11.7 cm x 6.7 cm x 2.7 cm
114 g
1 year
Network tester
Media
Copper
Cable Types
Carrying pouch, 2 x RJ-45 to F-connector adapters
1 x RJ-45 to RJ-45 patch cable - 15 m
Connectors
RJ-45, RJ-12, RJ-11, 9 pin USB type A, 9 pin USB type B, RJ-9, RJ-14, RJ-25, RJ-61
Warranty
1 year
Voltage
9 V
Included Qty
0
Required Qty
1
11.7 cm
6.7 cm
2.7 cm
114 g
50 °C
0 - 95% (non-condensing)
