StarTech.com Temperature/Humidity Meter
Quicklinx: J1KQWS00 Mfr#: DH60-THERMOMETER
£23.56 ex VAT
£28.27 inc VAT
The StarTech.com DH60-THERMOMETER is a reliable handheld thermo-hygrometer that provides accurate temperature and humidity readings for a variety of environments. Designed with an easy-to-read LCD display, it allows users to monitor conditions effortlessly in both Celsius and Fahrenheit. With a wide measuring range from -10°C to 60°C and humidity levels from 0% to 100%, this device is suitable for home, office, or outdoor use. It features a low battery indicator, data hold function, and auto shut-off, ensuring that measurements are taken with ease and efficiency. This digital thermo-hygrometer is compact and portable, making it ideal for on-the-go monitoring. It meets several compliance standards including EMC, FCC, RoHS, and REACH, ensuring reliability and safety in its use. The dual capability of measuring both temperature and humidity with high accuracy and a resolution of 0.1°C and 0.1% respectively makes it an essential tool for anyone looking to maintain optimal environmental conditions.
  • Accurate measurements
    This thermo-hygrometer provides precise readings with a measurement accuracy of +/- 1° for temperature and +/- 5% for humidity, making it valuable for various applications.
  • User-friendly display
    The LCD display presents temperature and humidity levels clearly, allowing for easy monitoring at a glance, whether indoors or outdoors.
  • Energy-efficient operation
    With an auto shut-off feature, the device conserves battery life, prolonging usage time and ensuring readiness when needed.
  • Versatile measurement range
    The device can measure temperatures from -10°C to 60°C and humidity from 0% to 100%, catering to a wide range of environmental conditions.
  • Convenient features
    Additional features such as the data hold function enhance usability, making it easy to capture and retain readings for further analysis.
StarTech.com - thermo-hygrometer
Thermo-hygrometer - digital
Measuring Functions
Temperature, humidity
Thermometer Scale
Celsius, Fahrenheit
3 AAA batteries
Display
LCD
Grey
5 cm x 3 cm x 14.5 cm
Installation Type
Handheld
Measuring Functions
Display
LCD
Thermometer Scale
Celsius, Fahrenheit
Data hold function, auto shut-off, low battery indicator
Weather Measuring
Parameter
Temperature: -10 °C to 60 °C - resolution: 0.1 °C - accuracy: +/- 1° , Humidity: 0 % to 100 % - resolution: 0.1 % - accuracy: +/- 5%
AAA type
Required Qty
3
3 AAA batteries
Grey
FCC, EMC, RoHS, REACH
5 cm
3 cm
14.5 cm
190 g
Shipping Width
10.6 cm
Shipping Depth
3.5 cm
Shipping Height
2.1 cm
Shipping Weight
200 g
J1KQ StarTech.com Temperature/Humidity Meter In Stock £23.56
J1KQ StarTech.com Handheld Sound Level Meter In Stock £22.96
