StarTech.com Handheld Sound Level Meter
Quicklinx: J1LZWS00 Mfr#: D130-DECIBEL-METER
28 In Stock
£25.95 ex VAT
£31.14 inc VAT
The Handheld Digital Sound Meter by StarTech.com is a reliable tool designed for accurate sound measurement in various environments. With its LCD display and LED backlit display, users can easily read measurements in any lighting condition. The device features a sensitive range of 30-130 dBA, providing precision with a resolution of 0.1 dB and a measurement accuracy of 1.5 dB. The sound meter includes a data hold function, allowing users to capture and retain reading results for later reference. Constructed from durable ABS plastic and compliant with IP54 standards, this sound meter withstands everyday use. The non-slip design ensures a secure grip during operation, while the auto shut-off feature preserves battery life. With both slow and fast mode sensor readings, users can adapt their measurements to a variety of applications, making this handheld sound meter a versatile choice for professionals and enthusiasts alike.
  • Accurate measurements
    With a measurement accuracy of 1.5 dB, this sound meter provides reliable readings for various sound levels.
  • Versatile sensor modes
    Choose between slow mode sensor reading at 1 second or fast mode at 1/8 second for efficient sound measurement.
  • User-friendly design
    Equipped with an LED backlit display, this device ensures that measurements can be easily read even in low-light conditions.
  • Energy-saving features
    The auto shut-off feature helps extend battery life, making this sound meter practical and efficient.
  • Secure grip
    The non-slip design enhances user comfort and stability during operation, allowing for better handling.
StarTech.com Handheld Digital Sound Meter, Noise/Decibel Level Reader - sound meter - black
Sound meter
Sensor Type
Sound
Integrated Components
Microphone
Power Source
5 cm x 2.9 cm x 16.3 cm
Sound meter
Sensor Type
Sound
Microphone
Power Source
LCD display, LED backlit display, 30-130dBA sensitive range, data hold function, auto shut-off, non-slip design, 0.1dB resolution, slow mode sensor reading (1s), fast mode sensor reading (1/8s)
Measurement Accuracy
1.5db
Product Material
ABS plastic
Warranty
IP54
5 cm
2.9 cm
16.3 cm
190 g
Shipping Width
10.6 cm
Shipping Depth
3.5 cm
Shipping Height
21.4 cm
Shipping Weight
200 g
J1LZ StarTech.com Temperature/Humidity Meter In Stock £24.79
