Brand
TRENDnet 150MBPS Wireless N 3G Router
Quicklinx: B4FWWS00 Mfr#: TEW-655BR3G
Type: Wireless router
Connection Type: [N/A]
Standards: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0), Ethernet + 1 more
Speed: 150Mbps
Rackmount or External: External
  • IEEE 802.11n (draft 2.0)
£54.99 ex VAT
£65.98 inc VAT
The 150Mbps mobile wireless N router connects to the Internet either using a traditional hard wired connection or by cutting the cables and connecting with a compatible wireless mobile USB dongle from a 3G Internet service provider.
Designed for true portability the router has a rechargeable and replaceable 2.5 hour lithium ion battery. Compatible with USB dongles from every mobile provider, this compact router connects to the Internet anywhere there is a 3G mobile connection.
No installation is required, simply plug the 3G USB adapter into the router to share a single Internet connection. The wireless encryption protects your valuable data. Wi-Fi Protected Setup (WPS) integrates other WPS supported clients at the touch of a button. An on/off switch on the back of the devices saves battery life.
TRENDnet TEW-655BR3G - wireless router - 802.11b/g/n (draft 2.0) - desktop
Wireless router
Enclosure Type
Desktop
Mobile Communication Protocol
CDMA 2000, UMTS, TD-SCDMA, WCDMA, HSPA
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, MAC address filtering, URL filtering, IP address filtering, MIMO technology, event log, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n (draft 2.0), UPnP
7.6 cm x 10.7 cm x 2.1 cm
97.4 g
3-year warranty
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
PPTP, L2TP, PPPoE
Routing Protocol
RIP-1, RIP-2
HTTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n (draft 2.0), UPnP, FCC, RoHS
Status Indicators
Port status, power, link/activity
Line Properties
Line Coding Format
CCK, BPSK, QPSK, OFDM
Communications
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
External power adapter
7.6 cm
10.7 cm
2.1 cm
97.4 g
Limited warranty - 3 years
45 °C
0 - 95%
Standards: IEEE 802.11g
Standards: IEEE 802.11n (draft 2.0)
Standards: Ethernet
Standards: Fast Ethernet
Speed: 150Mbps
Brand: TRENDnet
