Incredible speed
Drastically improved WiFi 6 speeds enable streaming, fast downloading, and gaming - all at the same time. 5 GHz with 160 MHz channel support doubles the bandwidth, enabling 8K video without lag. -
Go faster - multi-gig wired connections
In addition to stunning wireless speeds, AX55 Pro also provides premium wired connections. A 2.5 Gbps port and 1 Gbps port make full use of gigabit speeds from your local ISP. Break through the 1G bottleneck and drive your devices to peak performance. WAN/LAN support gives you remarkable flexibility to tailor both ports to fit your network's needs. -
WiFi coverage throughout your home
4× high-performance antennas boost WiFi signals throughout your home. Beamforming technology detects devices and concentrates signals towards them, especially to previously hard-to-reach areas. -
Massively expanded device capacity
Enjoy smooth gaming, video streaming, and live feeds simultaneously. OFDMA makes your WiFi stronger by allowing multiple clients to share one band at the same time, which cuts latency and jittering. -
Improved cooling design for full output
No heat ups, no throttles. A larger heat sink and refined case design cool the WiFi 6 system and enable your network to stay at top speed in more versatile environments. -
Flexibly create whole home WiFi with Archer AX55 Pro
Want to build a whole-home Wi-Fi? Archer AX55 Pro supports OneMesh to form seamless whole-home coverage, preventing drops and lag when moving between signals. -
Advanced security for your everyday devices
With TP-Link HomeShield, enjoy advanced security features delivering a safe environment that protects your family and network's data and privacy. -
VPN clients and server supported
Allow devices in your home network to access remote VPN servers without needing to install VPN software on every device. Archer AX55 Pro can run both the VPN and ordinary internet connections at the same time, delivering security and flexibility. -
USB 3.0 ports
Easily share files between connected devices by plugging into an external drive. You can even make it your personal cloud storage and access it from outside securely. -
Easy setup and use
Whether you prefer the intuitive Tether app or TP-Link's powerful web interface, you can set up your Archer AX55 Pro in minutes. The Tether app allows you to manage network settings from any Android or iOS device.
 - TP-Link Archer AX55 Pro V1 - wireless router - Wi-Fi 6 - desktop
 - Wireless router - 5-port switch (integrated)
- Enclosure Type
 - Desktop
- WAN Ports Qty
 - 2
- Data Link Protocol
 - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
- Frequency Band
 - 2.4 GHz / 5 GHz
- Data Transfer Rate
 - 2042 Mbps
- Routing Protocol
 - Static IP routing
 - NAT support, VPN support, SPI, parental control, ACL support, QoS, WPS, DHCP server, FTP server, port forwarding, UPnP Media Server, reset button, port triggering, dynamic IP mode, DHCP client, power-saving mode, beamforming technology, Smart Connect, Airtime Fairness, DMZ support, OpenVPN client, OpenVPN server, 8K HD video streaming, OneMesh support, Guest Network, TP-Link HomeShield
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
- Power
 - 12 V 1.5 A
 - 26.11 cm x 13.45 cm x 4.1 cm
 - 3-year warranty
- Enclosure Type
 - Desktop
- Connectivity Technology
 - Wireless, wired
- Frequency Band
 - 2.4 GHz / 5 GHz
 - 2042 Mbps
- Routing Protocol
 - Static IP routing
- Encryption Algorithm
 - WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPS, WPA3
- Wi-Fi Rating
 - AX3000
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, FCC, RoHS
- Status Indicators
 - Status
Line Properties
- Line Coding Format
 - OFDMA
 - LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN / LAN: 1 x 1000Base-X - RJ-45
Aerial
- Aerial
 - External
- Antenna Qty
 - 4
- Directivity
 - Directional
- Power Device
 - External power adapter
- Voltage Required
 - 12 V
- Electric Current Required
 - 1.5 A
- Cables Included
 - 1 x network cable
- Software Included
 - Microsoft Internet Explorer 11, Safari 4.0+, Chrome 20.0+, Firefox 12.0+
 - 26.11 cm
 - 13.45 cm
 - 4.1 cm
 - Limited warranty - 3 years
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
