TRENDnet 1000Base-T to 1000Base-FX Multi-Mode SC Fiber Converter
Quicklinx: 9YLRWS00 Mfr#: TFC-1000MSC
TRENDnet's TFC-1000 series Fiber Media Converter transforms 1000BaseT (Copper Gigabit) media to 1000BaseSX/LX (Fiber Gigabit) media and vice versa. The 1000BaseT port supports full-duplex Gigabit connection at wire speed with RJ45 connector. The fiber Gigabit connection supports shortwave (SX) or longwave (LX) laser optic with multi-mode or single-mode SC type connector. This converter will give your Copper Gigabit connection the ability to interface with fiber connection over a distance up to 20 km. With the optional 16-slot EIA-19" rack-mount chassis, the TFC series converters are the perfect solutions for various fiber media.
TFC-1000MSC is a 1000BaseT to 1000BaseSX Multi-Mode Fiber Converter with SC Connector.
TRENDnet TFC-1000 - fibre media converter - 1GbE - TAA Compliant
Fibre media converter - RJ-45 / SC multi-mode
External
Cabling Type
1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Remote Management Protocol
SNMP
Max Transfer Distance
550 m
12 cm x 8.8 cm x 2.5 cm
0.4 kg
TAA Compliant
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
SNMP
550 m
Status Indicators
Power, link/activity
Full duplex capability
IEEE 802.3z, IEEE 802.3ab
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 100Base-SX - SC multi-mode female x 2
VCCI
TAA Compliant
External power adapter
7.2 Watt
12 cm
8.8 cm
2.5 cm
0.4 kg
Limited warranty - lifetime
10 - 90%
