TRENDnet Gigabit Ultra POE+ Injector
Quicklinx: FQ82WS00 Mfr#: TPE-117GI
TRENDnet's Gigabit Ultra PoE+ Injector, model TPE-117GI, combines electrical power with a Gigabit network connection to produce a Gigabit Ultra Power over Ethernet Plus signal. Auto-sensing technology conveniently delivers the correct wattage needed to power your Ultra PoE devices and PoE+ devices. Use an existing open port from a non-PoE switch to save installation and equipment costs when installing TRENDnet PoE access points and IP cameras in remote locations.
  • PoE
    Supplies a PoE device with PoE (15.4 watts), PoE+ (30 watts), or Ultra PoE (60 watts) power.
  • Plug and Play
    Plug and play PoE network devices - no configuration needed.
  • Installation flexibility
    Wall-mount design and a sturdy metal enclosure accommodates most installations scenarios.
  • LED indicators
    LED indicators confirm PoE and network connectivity.
  • Auto-sensing technology
    Auto-sensing technology delivers up to 60 watts to an Ultra PoE device with backwards compatibility for 802.3at PoE+ (30 watts) and 802.3af PoE (15 watts) devices.
TRENDnet TPE-117GI - PoE injector - 60 watt
PoE injector - external
185 g
Power Capacity
60 watt
Input Connectors
1 x power
Output connectors
1 x RJ-45
Power adapter
12 cm x 7.5 cm x 2.2 cm
3-year warranty
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Input Connectors
1 x power
1 x RJ-45
Power Capacity
60 watt
1 x Gigabit LAN - RJ-45
Power adapter
Power cable - external
Wall mountable, LED indicators, Auto-Sensing Technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, IEEE 802.3bt (draft), Plug and Play, FCC
Limited warranty - 3 years
60 °C
0 - 95% (non-condensing)
12 cm
7.5 cm
2.2 cm
185 g
