- 450Mbps Wireless speed and Gigabit Ethernet ports are ideal for multiple HD video streaming
- Multi-functional USB 2.0 port - Easily share a printer locally and files & media with networked devices or remotely via FTP server
- Wireless security encryption easily at a push of WPS Button
Wireless Speed Up To 450Mbps 2.4GHz Set To Maximum
With wireless speeds of up to 450Mbps, the maximum speed available on a 2.4GHz single band, you can enjoy HD video streaming and online gaming with an even more fluid experience than 300Mbps and 150Mbps.
Fully extended coverage
3*5dBi antennas
3 external 5dBi antennas combined with higher quality antenna technology provide users with larger wireless coverage and stronger wireless signal intensity from anywhere in your large home or office.
Blazing Wired Speeds
5 Gigabit Ports + 800Mbps Hardware NAT
With 5 built-in gigabit ports and a Hardware NAT function, the wireless router provides powerful data processing capabilities. Its NAT WAN to LAN throughput can achieve up to 800Mbps+ allowing users to unleash the full potential of their networks.
Easy for Sharing
Multi-functional USB Port
Using the TL-WR1043’s multi-functional USB ports, users can share printers, files and media either throughout the network at home with several different computers or even away. Using the device’s ftp server functions so that you never have to part with your files.
Wireless speed up to 450 Mbps 2.4 GHz set to maximum
With wireless speeds of up to 450 Mbps, the maximum speed available on a 2.4 GHz single band, you can enjoy HD video streaming and online gaming with an even more fluid experience than 300 Mbps and 150 Mbps. -
3 external 5 dBi antennas combined with higher quality antenna technology provide users with larger wireless coverage and stronger wireless signal intensity from anywhere in your large home or office. -
Blazing wired speeds
With 5 built-in gigabit ports and a Hardware NAT function, the wireless router provides powerful data processing capabilities. Its NAT WAN to LAN throughput can achieve up to 800Mbps+ allowing users to unleash the full potential of their networks. -
Easy for sharing - multi-functional USB port
Using the TL-WR1043's multi-functional USB ports, users can share printers, files and media either throughout the network at home with several different computers or even away. Using the device's ftp server functions so that you never have to part with your files.
- TP-Link TL-WR1043ND V3 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 450 Mbps
- PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Firewall protection, DMZ port, SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, VPN passthrough, WDS support, URL filtering, IP address filtering, firmware upgradable, virtual server support, DHCP server, DHCP client
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n, UPnP
- 22.5 cm x 14.1 cm x 3 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 2000/XP/Vista/7/8
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 450 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n, UPnP, FCC Class B certified, RoHS
- Status Indicators
- Power, link OK, system, status, link/activity
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
- OS Required
- 22.5 cm
- 14.1 cm
- 3 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
