Expand your Wi-Fi network using your home's existing powerlines. Plug in the TL-WPA8630P to transmit an Internet connection to any area in your home and share that connection with all of your favorite wired and wireless devices. A unified network keeps your connection stable, even as you move around the house.
Expansive coverage
2x2 MIMO with beamforming technology offers the benefit of improved coverage throughout the home, particularly for previously hard to reach outlets. -
Unified Wi-Fi network
Wi-Fi auto-sync creates a simple, intuitive powerline experience. Pressing the Wi-Fi clone button instantly copies your network name and password from your router for easy setup. Wi-Fi move automatically applies any settings changes across the network.
- TP-Link TL-WPA8630P AV1300 Gigabit Passthrough Powerline ac Wi-Fi Extender - powerline adapter - Wi-Fi 5 - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1300 Mbps
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Parental control, MIMO technology, reset button, Wi-Fi Move technology, Wi-Fi Clone button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac
- 7.5 cm x 4.2 cm x 15.2 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1, Windows 10
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1300 Mbps
- Max Range Indoors
- 300 m
- Routing Protocol
- Encryption Algorithm
- WPA-PSK, 128-bit AES, WPA2-PSK, WEP
- Authentication Method
- Radio Service Set ID (SSID)
- Wi-Fi Rating
- AC1350
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac, RoHS
- Status Indicators
- Power, LAN, powerline, Wi-Fi
Line Properties
- Line Coding Format
- OFDM
- LAN: 3 x Ethernet 1000
- Power Device
- Internal power supply
- 11 Watt
- Cables Included
- Network cable
- OS Required
- 7.5 cm
- 4.2 cm
- 15.2 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
