1080p Full HD Live View-Reveals clear and sharp images with more details.
Person Detection and Motion Tracking-Smart AI identifies a person while tracking motion with high-speed rotation, notifying users as needed.
360° Visual Coverage-Provides 360° horizontal & 130° vertical range to cover every corner.
Night Vision (up to 98 ft)-Ensures your safety by providing a clear visual distance of up to 98 ft even in total darkness.
IP65 Weatherproof-Offers excellent waterproof and dustproof performance for outdoor scenarios.
Multiple Installation Options-Use the mounting screws, template and loops‡ to install on any wall, ceiling or pole for the perfect view—wherever you want.
Flexible Storage Choices-Save recorded videos to an installed microSD card(up to 512 GB)†, or use Tapo Care** cloud storage service.
Customizable Sound Alarm-Record your customized audio as an alarm to extend your usages.
Physical Privacy Mode-Maintains your privacy with the lens physically blocked by the housing.
Two-Way Audio-Enables communication through a built-in microphone and speaker.
Person detection and motion tracking
Smart AI identifies a person while tracking motion with high-speed rotation, notifying users as needed. -
1080p Full HD, clear every second
Capture more details to make every moment shine. -
IP65 water and dust resistant
Offers excellent waterproof and dustproof performance for outdoor scenarios. -
Customizable sound alarm
- Tapo C500 V1 - network surveillance camera
- Network surveillance camera - fixed - indoor, outdoor - dust resistant / water resistant
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- Camera Mount Type
- Ceiling mount
- 12.38 cm x 12.3 cm x 9 cm
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 15 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- 1/3"
- Focal Length Control
- Fixed focal
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, 2.4GHz radio
- Intelligent Assistant
- Alexa, Google Assistant
- Voltage
- AC 100-240 V
- Person Detection, reset button, LED indicator, motion detection
- Environmental Parameters (operating)
- -30 °C - 60 °C; 10 - 90% RH (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Ceiling mount
- Wireless
- 12.38 cm
- 12.3 cm
- 9 cm
Camera
- Colour - Day&Night - fixed - indoor, outdoor - dust resistant / water resistant
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 15 m
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
Image Sensor
- 1/3"
Lens Construction
- Fixed focal
- Network Interface
- Network Protocols
- TCP/IP, ICMP, DNS, HTTPS, UDP/IP
- Included Accessories
- Anchors, mounting template, mounting bracket, screw, power adapter, waterproof seal plug
- WPA, WPA2-PSK, AES-128, SSL, TLS, RoHS, RCM, FCC
- Power Device
- Power adapter AC 100-240 V (50/60 Hz)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 10 - 90% RH (non-condensing)
