TP LINK KC200 Kasa Outdoor Cam
Quicklinx: F8L0WS00 Mfr#: KC200
The Kasa cam outdoor is a full-featured weatherproof security camera that you can access from anywhere. Day or night, rain or shine, Kasa cam protects what you love.
Protect Your Outdoors
Use crisp 2-way audio to communicate with the delivery person at your front door or use the siren to scare away intruders.
Crystal Clear Video
Sharp and clear, wide-angle 1080P video makes sure you never miss a thing. Manually zoom in to get a closer look to what's going on, day or night.
Easy DIY Install
Get the best angle and video with your Kasa Cam Outdoor with an easy to follow installation process in the Kasa Smart app. The magnetic camera mount and mounting wall plate make for a quick set-up and allows you to configure your camera for the best view.
Watch from Anywhere
Watch live or recorded video at any time on your smartphone with the free Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, e.g. Fire TV or Google Chromecast.
Instant Notifications
Get instant alerts straight to your smartphone whenever your Kasa Cam Outdoor detects any sound or motion.
Weatherproof
The Kasa Cam Outdoor’s IP65 rating ensures your device will be protected against rain and dust.
  • Protect your outdoors
    Use crisp 2-way audio to greet the delivery person at your front door or use the siren to scare away intruders.
  • Made for everyday use
    Control what alerts you receive by creating up to 4 custom activity zones, at no charge, around areas that are important to you.
  • Protect every pixel
    Your privacy is important, which is why all your video streams are protected with superior encryption with SSL/TLS right from the camera.
TP-Link Kasa KC200 - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
7.395 cm x 7.355 cm x 8.628 cm
310 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
720p, 1080p, 360p
Optical Sensor Type
1/2.7"
Focal Length Control
Fixed focal
Focal Length
3.21 mm
Lens Iris
F/2.0
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Intelligent Assistant
Google Assistant, Alexa
1 - USB cable - external - 3.05 m
Voltage
DC 5 V
LED indicator, reset button, Audio Detection, built-in siren, WPA, WPA2-PSK, WEP
Environmental Parameters (operating)
-20 °C - 43 °C; 10 - 95% (non-condensing) relative humidity
Audio Support
Wireless
7.395 cm
7.355 cm
8.628 cm
310 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
720p, 1080p, 360p
Digital Zoom
8
Infrared LEDs
Infrared Distance
30 m
Video Capture
1920 x 1080 @ 30 fps
Image Sensor
1/2.7"
Lens Construction
Fixed focal
Focal Length
3.21 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
130
Network Interface
Network Protocols
TLS, SSL
Mounting kit, magnetic base plate
1 x USB cable - external - 3.05 m
IC, FCC, IP65
Power Requirements
DC 5 V - 1 A
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 (KitKat) or later, Apple iOS 10 or later
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Limited warranty - parts and labour - 2 years
Shipping Width
18.4 cm
Shipping Depth
15.4 cm
Shipping Height
10 cm
Shipping Weight
810 g
-20 °C
43 °C
Relative Humidity (operating)
