Get the full picture of any space in your apartment, dorm or home with the Kasa Spot Pan Tilt. With a 360° horizontal view and 113° vertical view, the Pan Tilt has everything covered. Receive real-time alerts through the Kasa app when your camera detects motion or sound activity. With all videos stored locally on a MicroSD card, access your video history and live stream 1080p HD video to your smartphone, Alexa or Google Assistant supported display. The Pan Tilt also features advanced night vision to capture activity up to 30 ft. away in the dark and allows you to set custom activity zones around important areas to control what alerts you receive.
Crystal clear video 24/7
Sharp and clear 1080p HD video 24/7 using night vision to detect motion up to 30 feet in the dark. -
Pan and tilt
With 360° rotational and 113° vertical views, The Pan Tilt camera can monitor every angle of any room. -
Motion tracking
The Kasa Spot intelligently tracks and monitors moving objects, giving you a clearer picture of what's occurring in your home. -
Patrol mode
Select multiple points of focus on in your home and let the camera automatically view each one at selected intervals. -
Real-time alerts
No need to check your Kasa Spot throughout the day. Get automatic alerts when it detects motion or sound. -
Two-way audio
Use crisp two-way audio to communicate with unexpected visitors. -
Activity zones
Configure up to 4 customizable zones to receive alerts you care about.
- TP-Link Kasa Spot KC115 - network surveillance camera
- Network surveillance camera - pan / tilt - indoor
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 8.2 cm x 8.2 cm x 11.26 cm
- 499 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 15 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- 1/2.7"
- Focal Length Control
- Fixed focal
- Focal Length
- 3.97 mm
- Lens Iris
- F/2.2
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 113
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Intelligent Assistant
- Alexa ready, Google Assistant ready
- Cables Included
- 1 - USB cable - external - 3.05 m
- Voltage
- DC 5 V
- Auto patrol, Push Notification, reset button, auto tracking, Smartphone Monitoring, Audio Detection, WPA, WPA2-PSK, WEP
- 2-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
- Audio Support
- Audio Formats
- AAC
- Wireless
- 8.2 cm
- 8.2 cm
- 11.26 cm
- 499 g
Camera
- Colour - Day&Night - pan / tilt - indoor
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 9.1 m
- Video Capture
- 1920 x 1080 @ 15 fps
Image Sensor
- 1/2.7"
Lens Construction
- Fixed focal
- Focal Length
- 3.97 mm
- Lens Iris
- F/2.2
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 113
- Network Interface
- Network Protocols
- TLS, SSL
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Mounting kit
- Cables Included
- 1 x USB cable - external - 3.05 m
- IC, FCC, RoHS, AES-128
- Power Requirements
- DC 5 V - 2 A
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz)
- OS Required
- Android 5.0 or later, Apple iOS 10 or later
Internet of Things (IoT)
- Supported Host Device Platform
- iOS, Android
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 10 - 90% (non-condensing)
