TP LINK JetStream 24-Port Gigabit Stackable Smart Switch
Quicklinx: CMC9WS00 Mfr#: T1700G-28TQ
TP-LINK's Gigabit stackable smart switch, the T1700G-28TQ, is designed to help you build a network that is highly accessible, scalable, and robust. The switch is equipped with 24 10/100/100Mbps RJ-45 ports and 4 dedicated 10G SFP+ slots which can be used for uplinks and/or stacking, providing a strong interconnection between access and aggregation. It provides excellent performance, powerful L2 and L2+ features, enterprise-level QoS, and effective security strategies. Besides, with physical stacking improving performance and simplifies management, T1700G-28TQ is able to provide reliable, cost-effective networking solutions for SMBs.
  • Physical stacking
    Physical stacking technology connects multiple devices to form a unified system which allows multiple devices to work together and be managed as a single unit, which improves performance and simplifies management. The switch supports up to 6 units in a stack offering high-density developments as well as flexibility for network expansion need.
  • Abundant L2 and L2+ features
    The T1700G-28TQ supports rich L2 features, including 802.1Q tag VLAN, Port Isolation, Port Mirroring, STP/RSTP/MSTP, Link Aggregation Groups, and 802.3x Flow Control function. Additionally, the switch provides advanced features for network maintenance, such as Loop Back Detection, Cable Diagnostics, and IGMP Snooping. IGMP snooping ensures that the switch can intelligently forward the multicast stream only to the appropriate subscribers, while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access. Besides, T1700G-28TQ supports L2+ feature: static routing, which provides simple network segmentation by routing internal transmissions to make the flow of network traffic more efficient.
  • Advanced QoS features
    To support voice, data, and video services on one network, the switch utilizes rich QoS policies. Administrators can prioritize traffic based on a variety of factors, including Port Priority, 802.1P Priority, and DSCP Priority, to ensure that voice and video streams are always clear and smooth.
  • Enterprise-level management features
    The T1700G-28TQ is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based graphical user interface (GUI), industry-standard command line interface (CLI), SNMP, and RMON. This allows the switch to provide valuable status information and send reports on abnormal events.
TP-Link JetStream T1700G-28TQ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance: 95.2 Mpps
IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP groups: 1000 , VLAN groups: 4000 , Priority queues per port: 8 , ACL entries: 300
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, SSH-2, CLI
Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DAI, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, DHCP relay, IP-MAC binding, SNMP trap, NDP, port isolation, CoS, Loopback, DSCP support, 1.5MB packet buffer, system log, CPU protection, ICMP, dual image support
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
44 cm x 18 cm x 4.4 cm
2.8 kg
UNIX, Apple MacOS, Linux, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Max Units In A Stack
6
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0
Authentication Method
Secure Shell (SSH), Secure Shell v.2 (SSH2)
Status Indicators
Power, system, link/activity
24 x 1000Base-T RJ-45 , 4 x 10Gbit LAN SFP+
Internal power supply
21.8 Watt
4 rubber feet
Rack Mounting Kit
Included
FCC, RoHS
Software Included
Drivers & Utilities
44 cm
18 cm
4.4 cm
2.8 kg
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
