TP LINK JetStream 24-Port 10/100Mbps + 4-Port Gigabit L2 Managed
Quicklinx: BJ7JWS00 Mfr#: TL-SL3428
The TL-SL3428 24+4G Gigabit-uplink managed switch fully complies with IEEE 802.3/802.3u/802.3ab/802.3z Ethernet standards. It provides 24 10/100Mbps and 2 10/100/1000Mbps UTP/STP RJ45 ports with auto-MDI/MDIX and 2 SFP independence expansion slots supporting MiniGBIC modules. It also provides powerful management functions, including the system, port, network, spanning tree protocol, IEEE 802.1X protocol, VLAN, Trunk, IGMP Snooping, SNMP protocol, priority and security.
The TL-SL3428 switch provides multiple management methods: SNMP, Web and telnet/console. Its standard 19-inch rack-mountable steel case and intelligent management make it is suitable for small, middle and large networks.
TP-Link TL-SL3428 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
Auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8K entries
Status Indicators
Power, 100M device connected, 1000M device connected, link/activity
24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 1 x serial (RS-232) DB-9 management , 2 x SFP (mini-GBIC)
Internal power supply
FCC
44 cm
18 cm
4.4 cm
10 - 90%
