TP LINK AV600 2-port Passthrough Powerline Starter Kit
Quicklinx: CMBCWS00 Mfr#: TL-PA4020P KIT V1.20
The TL-PA4020PKIT turns your home’s existing electrical circuitry into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapter into a power socket and you can establish networking infrastructure in a flash. In addition, its integrated power socket makes sure that no power outlet is going to waste. With speeds up to 600Mbps and 300 meters over the household electric wiring, the TL-PA4020PKIT is a great choice for an easy to build multimedia entertainment network.
  • Up to 600Mbps, 300 meters
    With advanced HomePlug AV technology, the TL-PA4020PKIT can provide users with stable high-speed data transmission rates of up to 600Mbps over a household electric circuit for up to 300 meters. The TL-PA4020PKIT is a great choice for a whole home solution to connect all network compatible devices - from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
  • Extra power socket for additional devices
    With its integrated power socket, the TL-PA4020PKIT provides real convenience for your home network. The integrated power socket allows an additional device or power bar to be connected to the adapter as though it were a normal wall socket. This ensures that even with the TL-PA4020PKIT plugged in, no power outlet goes to waste.
  • Pair button for easy network security
    You can set up a hassle-free powerline network within minutes with TP-LINK's powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
  • Mains filter for better performance
    With its Integrated Mains Filter, the TL-PA4020PKIT can optimize powerline communication performance by suppressing noise interference generated by surrounding electronic equipment that can affect network performance. That means that users won't experience a sudden speed drop when a larger power consuming device is plugged into the power socket.
  • Reduce power consumption by up to 85%
    The TL-PA4020PKIT, with its practical product design and environment-conscious Power-Saving Mode, will automatically switch from its regular "Working Mode" to "Power-Saving Mode" that will reduce energy consumption by up to 85%.
TP-Link TL-PA4020PKIT AV600 2-Port Powerline Adapter with AC Pass Through - V1.20 - Starter Kit - powerline adapter kit - wall-pluggable
Powerline adapter kit
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
600 Mbps
Integrated power socket
IEEE 802.3, IEEE 802.3u, HomePlug AV
5.8 cm x 4.2 cm x 9.5 cm
Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
600 Mbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, FCC, RoHS
Line Properties
Line Coding Format
OFDM
LAN: 1 x HomePlug AV - power , LAN: 2 x 10Base-T/100Base-TX - RJ-45
Internal power supply
5.2 Watt
1 x network cable
Software Included
Drivers & Utilities
5.8 cm
4.2 cm
9.5 cm
10 - 90% (non-condensing)
