Comes with advanced HomePlug AV2 technology, TL-PA7020 KIT provides users with high-speed data transfer rates of up to 1000 Mbps, which is ideal for bandwidth intensive applications such as multiple HD/3D/4K video streaming, online gaming and large file transfers.
With 2 gigabit Ethernet ports, TL-PA7020 KIT can simultaneously connect up to 2 wired-only devices. This makes the TL-PA7020 KIT the perfect home entertainment companion. Connect any 2 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go!
Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you're done!
Ideal for slick streaming and smooth downloads
Comes with advanced HomePlug AV2 technology, TL-PA7020 KIT provides users with high-speed data transfer rates of up to 1000 Mbps, which is ideal for bandwidth intensive applications such as multiple HD/3D/4K video streaming, online gaming and large file transfers. -
2 gigabit ports for maximum connectivity
With 2 gigabit Ethernet ports, TL-PA7020 KIT can simultaneously connect up to 2 wired-only devices. This makes the TL-PA7020 KIT the perfect home entertainment companion. Connect any 2 devices from smart TVs and games consoles to NAS boxes and computers to the Internet at the same time. Just plug the Ethernet cable into the powerline and away you go! -
Plug-and-Play, no configuration required
Connect a powerline adapter to the router; plug another powerline adapter into a wall socket in another room, and connect it to your Internet enabled device via Ethernet - and you're done! -
Reduce power consumption by up to 85%
TTL-PA7020 KIT, a new-generation of powerline adapter, with its practical design and sophisticated Power-Saving mode, will automatically switch from its regular "Working" mode to "Power-Saving" mode reducing its energy consumption by up to 85%.
- TP-Link TL-PA7020 KIT - Starter Kit - powerline adapter kit - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0
- Data Transfer Rate
- 1 Gbps
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Quality of Service (QoS), Type of Service (ToS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0
- Power
- AC 230V (50 Hz)
- 12.3 cm x 6.8 cm x 3 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7, Windows 8, Windows 8.1
- Localisation
- United Kingdom
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 1 Gbps
- Routing Protocol
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, HomePlug AV, HomePlug AV 2.0, Plug and Play, RoHS
- Status Indicators
- Power, LAN
Line Properties
- Line Coding Format
- OFDM
- LAN: 1 x HomePlug AV 2.0 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 5.7 Watt
- Cables Included
- 1 x network cable - 2 m
- Localisation
- United Kingdom
- OS Required
- 12.3 cm
- 6.8 cm
- 3 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
