TP LINK Archer C59 AC1350 Dual Band Wireless Cable Router
Quicklinx: CM9NWS00 Mfr#: Archer C59
  • IEEE 802.11n
The Archer C59 comes with the brand new Wi-Fi standard - 802.11ac, widely compatible with both wireless AC and wireless N devices and three times faster than previous wireless N speeds. With this cutting edge technology, the Archer C59 offers you faster, stronger and more capable Wi-Fi. Simply put: a revolutionized network experience on all your devices.
The Archer C59 provides your entire home with simultaneous dual band Wi-Fi connections. The strong and stable 2.4GHz wireless band with 450Mbps Wi-Fi speed is perfect for sending emails, browsing the web or listening to music. Meanwhile, the 5GHz wireless band provides up to 867Mbps Wi-Fi speed for latency-sensitive entertainment so you can stream HD video, play online games and hold video chats all at the same time, without delay.
  • Your home network revolutionized
  • Lightning Wi-Fi powers perfect entertainment
  • Strong signal, great coverage
    The Archer C59's three high performance external antennas ensure full home Wi-Fi coverage. Combined with a dual band wireless network, its increased stability and range means you will no longer suffer from weak, dropped connections.
  • Versatile USB connectivity
    A USB 2.0 port makes the Archer C59 a truly resourceful gateway. Connect a printer to all devices and share a hard drive full of media through your home network, or via an ftp server whenever you're away.
  • Easy parental control
    Supervise children and staff with responsible access, controlled by parents or administrators. Use URL blocking to easily set up a black or white list and limit the level of web access.
  • Guest network access
    Allow guests to join your Wi-Fi network, while protecting your privacy. Make sharing easy, maintain security.
TP-Link Archer C59 AC1350 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.35 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
DoS attack prevention, print server, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, parental control, IP address filtering, Wi-Fi Multimedia (WMM) support, virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, Samba support, FTP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, Stateful Packet Inspection Firewall (SPIF), DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
22.5 cm x 14.8 cm x 3.3 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.35 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1350
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC, RoHS
Built-in Devices
Led panel
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
3
Gain Level
5 dBi
External power adapter
1 x network cable
Software Included
Drivers & Utilities
22.5 cm
14.8 cm
3.3 cm
10 - 90% (non-condensing)
