TP Link Archer AX90 Wireless Router - 802.11a/b/g/n/ac/ax - Desktop
Quicklinx: G6WDWS00 Mfr#: ARCHER AX90
  • IEEE 802.11n
£211.97 ex VAT
£254.36 inc VAT
Upgrade Your WiFi to 6
Ideal for Your Latest Phones and Laptops
The new generation of phones—such as iPhone 11, Galaxy Note 10, and Galaxy S10—and laptops already support WiFi 6, with many more on the way. Your router should, too. WiFi 6 holds great promise to future-proof your home network for the next several years. Now is the best time to embrace this new technology.
Powerful and Exquisite
Combining Tri-band WiFi with high-tech WiFi 6, Archer AX90 provides eight simultaneous data streams to open up more bandwidth and help your devices operate at full speed. Eight high gain antennas not only deliver boosted WiFi signals to every corner of your home, but also bring a sense of aesthetics.
Go Faster— Wired or Wireless
In addition to stunning wireless speeds of more than 6.6 Gbps, AX90 also provides premium wired connections. A 2.5 Gbps port and 1 Gbps port make full use of gigabit speeds from your local ISP. Break through the 1G bottleneck and drive your devices to peak performance. WAN/LAN support gives you remarkable flexibility to tailor both ports to fit your network’s needs.
Your Security is Our Priority
Let the Experts Secure Your Home
Customize your home network with enhanced security using TP-Link HomeShield's kit of built-in features. Whether you're identifying network security holes, limiting the time your children spend online, or blocking websites, HomeShield gives you the tools you need to fully manage your network.
WPA3—Stronger Security for Your Network
Building on the widespread adoption of WPA2, the latest WPA3 brings new capabilities to improve cybersecurity.
TP-Link OneMesh™ :
Flexibly Create Whole Home WiFi with Archer AX90
OneMesh™ is a simple way to form a Mesh network with a single WiFi name for seamless wholehome coverage. Just connect a OneMesh™ range extender to a OneMesh™ router. No more searching around for a stable connection.
  • Ideal for your phones and laptops
    The phones and laptops already support Wi-Fi 6, with many more on the way. Your router should, too. Wi-Fi 6 holds great promise to future-proof your home network for the next several years. Now is the best time to embrace this advanced technology.
  • Go faster - wired or wireless
    In addition to stunning wireless speeds of more than 6.6 Gbps, AX90 also provides premium wired connections. A 2.5 Gbps port and 1 Gbps port make full use of gigabit speeds from your local ISP. Break through the 1G bottleneck and drive your devices to peak performance. WAN/LAN support gives you remarkable flexibility to tailor both ports to fit your network's needs.
  • Let the experts secure your home
  • WPA3 - stronger security for your network
    Building on the widespread adoption of WPA2, the WPA3 brings better capabilities to improve cybersecurity.
TP-Link Archer AX90 - wireless router - Wi-Fi 6 - desktop
Wireless router - 3-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
Network / Transport Protocol
PPTP, L2TP, PPPoE, FTP, DHCP, DDNS, IPv4, IPv6
Routing Protocol
IGMP, static IP routing
NAT support, IGMP snooping, SPI, DFS support, URL filtering, parental control, Access Point operational mode, firmware upgradable, ACL support, QoS, virtual server support, WPS, FTP server, static IP mode, port forwarding, reset button, Apple Time Machine compatible, port triggering, dynamic IP mode, IP-MAC binding, DHCP client, IGMP proxy, beamforming technology, Tri-Band, router mode, Airtime Fairness, 4x4 MU-MIMO technology, DMZ support, PPTP server, OFDMA, OpenVPN server, IPTV support, WPS button
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Wi-Fi Rating
AX6600
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, FCC, RoHS
1.5 GHz
Line Properties
Line Coding Format
OFDMA
WAN / LAN: 1 x 2.5GBase-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x , USB 2.0: 1 x
Aerial
Aerial
External integrated
Antenna Qty
8
External power adapter
1 x network cable
10 - 90% (non-condensing)
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: 2.5 Gigabit Ethernet
Standards: IEEE 802.11ac
Standards: IEEE 802.11ax (Wi-Fi 6)
Brand: TP LINK
