Toshiba 4GB DDR3/DDR3L 1600MHz SO DIMM Memory Module
Quicklinx: 96L5WS00 Mfr#: PA5104U-1M4G
Marketing description is not available.
Toshiba - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
Satellite C50, C50D, C50Dt, C50t, C55, C55D, C55Dt, C55T, C70, C70D, C75, C75D, C850, C870, L50, L50Dt, L50t, L55, L55t, L70, L75, L850, M50, M50D, M50Dt, NB10, NB10t, NB15t, P50, P50T, P55, P55T, P70, P75, S50, S50D, S50t, S55, S55DT, S55T, S70, S70t, S75, S75Dt, S75t, U50t, U940/K002
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
Toshiba Satellite C50-A-108, C50-A-10D, C50-A-12C, C50-A-14W, C50-A-1G4, C50-A-1HV, C50-A-1JM, C50-A-1JN, C50-A-1JU, C50-A-1KQ, C50-A-1LF, C50-A-1M0, C50-AST3NX1, C50D-A-10Z, C50D-A-130, C50D-A-131, C50D-A-13X, C50D-A-147, C50t-A-11D, C55-A-12W, C55-A-1F5, C55-A-1GT, C55-A-1N2, C55-A-1N4, C55-A-1N5, C55-A-1N8, C55-A-1N9, C55-A-1ND, C55-A-1NE, C55-A-1P2, C55-A-1P7, C55-A-1Q5, C55-A-1QH, C55-A-1R6, C55-A-1R7, C55-A-1R8, C55-A-1R9, C55-A-1RL, C55-A-1TK, C55-A-1U3, C55-A-1UE, C55-A-1UJ, C55-A5100, C55-A5105, C55-A5137, C55-A5140, C55-A5166, C55-A5172, C55-A5180, C55-A5308, C55-A5309, C55-A5310, C55-A5355, C55-A5388, C55-A5390, C55D-A-13T, C55D-A-15H, C55D-A5120, C55D-A5146, C55D-A5163, C55D-A5170, C55D-A5175, C55D-A5304, C55D-A5333, C55Dt-A5148, C55Dt-A5162, C55Dt-A5305, C55T-A5103, C55t-A5123, C55t-A5314, C70-A-13V, C70-A-14Z, C70-A-150, C70-A-157, C70-A-15D, C70-A-15G, C70-A-15U, C70-A-160, C70-A-162, C70-A-16L, C70-A-16N, C70-A-16P, C70-A-170, C70-A-17R, C70-A-17T, C70D-A-10H, C70D-A-10L, C70D-A-11C, C75-A-12D, C75-A-13M, C75-A-13T, C75-A-155, C75-A-15E, C75-A7120, C75-A7390, C75-B7180, C75D-A-10C, C75D-A7130, C75D-B7215, C75D-B7220, C75D-B7230, C75D-B7260, L50-A-1CE, L50-A-1CW, L50-A-1EC, L50-A-1EF, L50-A-1EH, L50-A-1F2, L50-A-1FM, L55-A5168, L55t-A5186NR, L55t-A5232, L70-A-10G, L70-A-13P, L75-B7150, L75-B7240, L75-B7270, M50-A-108, M50-A-113, M50D-A-10Q, M50D-A-118, M50Dt-A-103, M50Dt-A-210, NB10-A-10N, NB10t-A-10F, NB15t-A1302, NB15t-A1303, P50-A-113, P50-A-13C, P50-A-13Q, P50-A-144, P50-A-14F, P50-B-108, P50-B-10M, P50-B-10Q, P50-B-10R, P50-B-11L, P50-B-11R, P50t-A-129, P50t-B-104, P50t-B-10K, P50t-B-10T, P50t-B-113, P50T-B-11D, P55-B5162, P55t-A5116, P55T-B5154, P55T-B5156, P55t-B5262, P55T-B5360, P70-A-126, P75-A7200, S50D-A-10F, S50D-A-10G, S50D-A-10H, S55-A5154, S55-A5165, S55-A5169, S55-A5176, S55-A5197, S55-A5359, S55-A5364, S55DT-A5130, S55T-A5161, S55t-A5334, S55t-A5389, S75-A7140, S75-B7248, S75Dt-A7330
