Enhanced compatibility
Designed specifically for PC systems, this memory module ensures optimized performance, making it a suitable upgrade for system-specific needs. -
Efficient performance
With a memory speed of 1600 MHz and compliance with PC3L-12800 specifications, this DDR3L SDRAM module boosts your system's efficiency and responsiveness. -
Low power consumption
The low voltage feature of this memory module, requiring only 1.35 V, leads to reduced power consumption and a cooler running system, contributing to its longevity.
- QNAP - DDR3L - module - 2 GB - SO-DIMM 204-pin - 800 MHz / PC3L-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3L SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC3L-12800)
- Low Voltage, unbuffered
- Voltage
- 1.35 V
- 2-year warranty
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Non-ECC
- Voltage
- 1.35 V
- 2-year warranty
