Synology D3NS1866L-4G RAM Module
Quicklinx: D47RWS00 Mfr#: D3NS1866L-4G
Type: DDR3L SDRAM
Capacity: 4GB
Connection: SO-DIMM 204-pin
Speed: 1866MHz
Registered/Buffered: Unbuffered
£66.17 ex VAT
£79.40 inc VAT
Marketing description is not available.
Synology - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1866 MHz / PC3L-14900 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3L-14900)
Low Voltage, unbuffered
Voltage
1.35 V
Disk Station DS218+, DS418Play, DS620slim, DS718+, DS918+
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
Synology Disk Station DS218+, DS418Play, DS620slim, DS718+, DS918+
Type: DDR3L SDRAM
Capacity: 4GB
Speed: 1866MHz
Brand: Synology
