Boost your computer's boot-up and operation performance with Toshiba's 19 nm Solid State Drive technology. With a blazing fast SATA III interface, your computer's performance will make a quantum leap forward. The 7 mm slim SSD includes a spacer you will need for a firm fit in a 9.5 mm hard disk slot and also a cloning software you will need for exchanging your hard drive with the SSD.
- Toshiba Q300 Pro - SSD - 1024 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 1024 GB
- NAND Flash Memory Type
- 15nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Native Command Queuing (NCQ), TRIM support, Garbage Collection technology, Quadruple Swing by Code, Zero Trim Support, Adaptive Size SLC Write cache technology, Toshiba TC358790 controller, S.M.A.R.T.
- 69.85 mm x 100 mm x 7 mm
- 53 g
- 5-year warranty
- Capacity
- 1024 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 7 mm
- 53 g
Performance
- SSD Endurance
- 640 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 92000 IOPS
- 4KB Random Write
- 63000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3.3 watt (active) , 125 mW (idle)
- Software Included
- NTI Echo 3
- Included Accessories
- Mounting spacer
- Limited warranty - 5 years
- 0 °C
- 65 °C
