Sandisk Creator PRO Portable SSD - 2TB
Quicklinx: J04RWS00 Mfr#: SDSSDE81C-2T00-G25
Capacity: 2TB, 2TB
Interface: USB 3.2 Gen 2x2
Type: External hard drive
21 In Stock
£165.83 ex VAT
£198.99 inc VAT
Marketing description is not available.
  • Efficient Performance
    With an internal data rate of 2000 MBps, the SanDisk Creator Pro ensures quick access and transfer speeds for various files, making it suitable for tasks that require high performance.
  • Robust Protection
    Designed with an IP65 rating, this external hard drive resists both water and dust, providing peace of mind when storing valuable data in diverse environments.
  • Versatile Connectivity
    Featuring a USB-C port and including a USB-C to USB-A adapter, this drive connects seamlessly to a wide range of devices for ease of use and compatibility.
  • Ample Storage Capacity
    Offering 2 TB of storage space, the SanDisk Creator Pro enables users to store a large number of files, making it perfect for creatives and professionals alike.
  • Secure Design
    With a robust solid state drive format, this external hard drive provides reliable performance and durability, reducing the risk of data loss due to physical damage.
SanDisk Creator Pro - SSD - 2 TB - USB 3.2 Gen 2x2
Solid state drive - external (portable)
2 TB
USB 3.2 Gen 2x2 - USB-C
Data Transfer Rate
20 Gbps (USB 3.2 Gen 2x2)
Water resistant, dust-resistant
57.83 mm x 110.8 mm x 10.31 mm
77.5 g
5-year warranty
2 TB
USB 3.2 Gen 2x2
57.83 mm
110.8 mm
10.31 mm
77.5 g
Performance
Interface Transfer Rate
Internal Data Rate
2000 MBps (read) / 2000 MBps (write)
Expansion & Connectivity
1 x USB 3.2 Gen 2x2 - 24 pin USB-C
Software Included
Adobe Creative Cloud (1 month membership)
Windows 10 or later, Apple macOS 14 or later
1 x USB-C cable - external , 1 x USB-C to USB-A adapter - external
IP65
Shipping Width
10.3 cm
Shipping Depth
13.6 cm
Shipping Height
3.45 cm
Limited warranty - 5 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
Capacity: 2TB
Capacity: 2TB
Brand: Sandisk
