Synology RX1214RP delivers an effortless solution for volume expansion and data backup for Synology RackStation RS2414RP+. The /RX1214RP seamlessly scales up the storage capacity of the Synology RS2414RP+ by an additional 12 hard drives on-the-fly when connected directly to an expansion cable.
Volume expansion and backup
When running out of hard drive capacity on the Synology RackStation, Synology RX1214RP provides an easy way to immediately scale capacity by additional 12 hard drives. The RAID volume on the Synology RackStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology RackStation continues its service during the capacity expansion. Synology RX1214RP can be used as a dedicated local backup solution for the Synology RackStation. When created as a separate volume, the Synology RX1214RP provides a great backup solution to its local hard disks in case of system failure. -
Reliable Plug-n-Use design
Synology RS2414RP+ securely connects to Synology RX1214RP with a high-bandwidth expansion cable that ensures maximum throughput. It allows the hard drives in the connected Synology RX1214RP to operate as they are the internal ones of the Synology RS2414RP+, with no lag in data retrieval. With SATA III 6 Gb/s interface support, Synology RX1214RP unleashes the full performance of the installed drives and provides outstanding data transfer rate. -
Green and easy to manage
Deep sleep can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the hard disk. The RX1214RP will also smartly power on/off with the attached RackStation, so no user intervention is needed to keep this system running smartly and efficiently.
- Synology RX1214RP - storage enclosure - TAA Compliant
- Storage enclosure
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 24 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- Supported Drives
- SATA-600
- Hard Drive
- 12 x 2 TB HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- TAA Compliant
- 44.5 cm x 57 cm x 8.8 cm
- 5-year warranty
- Storage enclosure
- Enclosure Type
Chassis
- 12
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600
Storage
- 24 TB
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 2 TB
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x InfiniBand
- Built-in 4 cooling fans
- Cables Included
- 1 x InfiniBand cable
- FCC Class A certified, RoHS
- TAA Compliant
- Included Accessories
- Rail kit
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 121 Watt
- Power Provided
- 400 Watt
- 44.5 cm
- 57 cm
- 8.8 cm
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 42.2 dBA
