Synology RS3617RPXS72TB-REDPRO 12 Bay Rackmount NAS
Quicklinx: CFRHWS00 Mfr#: RS3617RPXS72TB-REDPRO
  • Xeon
  • Reliable centralized storage solution for large scale businesses
  • Blazing performance at over 3,829 MB/s throughput and 433,873 IOPS
  • Intel Xeon D-1521 Quad-Core 2.4GHz turbo boost to 2.7GHz
  • 8GB DDR4-2133 ECC UDIMM, expandable up to 64GB
  • Optional 10GbE network capability
Synology RackStation RS3617RPxs provides reliable, superior-performance network attached storage solution for large scale businesses with comprehensive business applications. RS3617RPxs simplifies data management, optimizes virtualization environments, and rapidly expands storage capacity with minimal time investment in setup and maintenance. Synology RS3617RPxs is backed with Synology’s 5-year limited warranty.
Blazing Performance
RS3617RPxs delivers blazing performance at over 3,829 MB/s sequential throughput and 433,873 IOPS under a RAID 5 configuration with 10GbE Link Aggregation enabled1. Through advanced flash technology, the combination of hard drives and SSD cache boosts throughput efficiently while minimizing cost per gigabyte. In addition to the four 1GbE RJ-45 ports by default, RS3617RPxs comes with dual PCIe 3.0 x8 slots, allowing installation of two 10GbE Network Interface Cards (NIC) to fulfill the demand of data-intensive applications. Equipped with 8GB DDR4 ECC UDIMM and up to 64GB expansion support, RS3617RPxs ensures data accuracy as well as superior performance to provide a rigorous foundation for the mission-critical tasks of your business.
Virtualization Ready
RS3617RPxs provides seamless storage solutions for virtualization environments, including VMware, Citrix, Hyper-V, and OpenStack Cinder. With VMware vSphere 6 and VAAI integration certified, RS3617RPxs helps offload specific storage operations and optimizes computation power for unparalleled performance and efficiency in VMware environments. As the centralized storage of a virtual environment, RS3617RPxs enables virtual machine migration, allowing movement from server to server whilst eliminating service downtime and disruption to user. Windows Offloaded Data Transfer (ODX) and Synology Advanced LUN support greatly improves the efficiency on massive data transfer and migration. With OpenStack Cinder support, RS3617RPxs can be used as a block-based storage component for servers complying with the Cinder API.
  • High-performance NAS server
    RS3617RPxs delivers stunning performance. Equipped with DDR4 ECC RAM, RS3617RPxs ensures data accuracy when handling high-value data and mission-critical tasks across large-scale businesses.
  • Scale on demand
    As your data storage needs grow, RS3617RPxs can be connected to one or two dedicated expansion units, allowing you to expand storage capacity without disrupting service. The high-bandwidth cable ensures speedy data transmission between the main server and expansion unit.
  • 10GbE network capability
    In addition to the four built-in Gigabit ports, RS3617RPxs comes with two PCIe 3.0 x8 slots that allow for the installation of two 10GbE network interface cards, maximizing bandwidth and meeting high-performance requirements for data-intensive applications.
  • Reliable redundancy mechanisms
    RS3617RPxs comes with comprehensive redundancy mechanisms to ensure business continuity. Built-in four LAN ports with failover provide reliable redundancy in the event of unexpected network failure. The high reliability system design, including fanless CPU heat-sink and passive cooling technologies, prevents a single point of failure. Other features such as redundant power supplies, system fans, and network ports with failover support ensure continual service uptime.
  • Enhanced encryption performance
    RS3617RPxs is equipped with an encryption engine which offloads encryption calculation tasks from the main CPU, thus allowing it to perform other important tasks. In addition, Advanced Encryption Standard (AES) on shared folders with hardware acceleration ensures security without compromising access performance.
  • SSD cache technology
    RS3617RPxs enables the combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS3617RPxs offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant server performance enhancement.
Synology RackStation RS3617RPxs - NAS server - 72 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
72 TB
12 (installed) / 12 (max)
69.2 cm x 43.05 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 6 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
75
RAM
8 GB
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
72 TB
69.2 cm
43.05 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
12 x 6 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Buffer Size
128 MB
Network / Transport Protocol
L2TP, iSCSI
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), antivirus analysis, Access Control List (ACL) support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED
Security DVR
75
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x InfiniBand
Wake on LAN, built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
