Synology RS2416RP+ 24TB (12 x 2TB RED PRO) 12 Bay NAS Solution
Quicklinx: BRS3WS00 Mfr#: RS2416RP+/24TB-RED PRO
  • Atom
Snapshots preserve the history of a shared folder allowing you to save up to 2561 backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance.
Btrfs file system stores two copies of critical metadata on a volume, improving the availability and survivability of your business's important data. By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator.
  • Fast and efficient snapshots
  • Metadata mirroring and survivability
  • Corruption detection and correction
  • Customizable quotas for shared folders
    With Btrfs, you can specify a storage limit for each shared folder, making it possible to precisely control space consumption when multiple teams or departments save files on the same Synology NAS server.
  • Speedy data encryption with AES-NI
    As businesses store more and more critical information in digital form, data encryption has become an essential aspect of any healthy security policy. Equipped with a dedicated AES-NI hardware encryption engine, RS2416RP+ delivers encrypted data transmission speeds over 399 MB/s reading and 198 MB/s writing, making it the ideal digital locker for your sensitive data.
  • Redundancy mechanisms for higher uptime
    RS2416RP+ includes redundant hardware mechanisms to ensure business continuity. The four built-in Ethernet ports with Link Aggregation and failover provide reliability in the event of unexpected hardware failure, while the hot-swappable drives to minimize system downtime during drive replacement. Redundant power supply units minimizes the chance of a complete system shutdown due to sudden power loss.
Synology RackStation RS2416RP+ - NAS server - 24 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
24 TB
Max Supported Capacity
96 TB
12 (installed) / 12 (max)
43 cm x 69.2 cm x 8.8 cm
1 x Atom C2358 1.7 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive
12 x 2 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Power Redundancy
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
24 TB
96 TB
43 cm
69.2 cm
8.8 cm
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
HDD
12 x 2 TB
Network / Transport Protocol
L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Calendaring Extensions to WebDAV (CalDAV)
LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
40
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x management
Built-in 4 cooling fans
RoHS
TAA Compliant
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Provided
500 Watt
TAA Compliant
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
44.3 dBA
