Synology RS217 12TB (2 x 6TB WD RED) 2 Bay Rack NAS Unit
Quicklinx: FW20WS00 Mfr#: RS217/12TB-RED
Designed for growing businesses, RS217 is a compact NAS providing stunning performance and a significant improvement in encrypted data processing. RS217 comes with comprehensive business applications, enhancing collaboration and productivity.
  • Improved performance
    Powered by a powerful processor, RS217 delivers impressive performance with encrypted high reading and writing speeds with link aggregation enabled. RS217 also delivers outstanding non-encrypted performance.
  • Dual LAN ensures continual network service
    RS217 comes with dual Gigabit Ethernet LAN ports with failover support to ensure continual network service in case of LAN failure. The hot-swappable design facilitates easy and risk-free hard drive replacement. The hard drive tray lock further secures your hard drives from unauthorized or accidental withdrawal.
  • Convenient connectivity
    RS217 enables faster and more efficient external data transfers. To ensure scalability, RS217 provides an eSATA and two USB 3.0 ports in the back, along with one USB 2.0 port on the front panel for quick access.
  • Modern collaboration tools
    RS217 comes with a comprehensive set of office applications, allowing you to maximize work productivity and improve team dynamics. Whether you are keeping track of household expenses or updating your project status, with SpreadSheet you can work together with other people on the same document in real-time as if you were sitting next to each other - even when you are miles apart. In addition, Note Station lets you and your team keep detailed notes and accomplish more tasks with features such as charts, presentation view, mail clipper, and much more.
Synology RackStation RS217 - NAS server - 12 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
12 TB
2 (installed) / 2 (max)
43.56 cm x 29.13 cm x 4.4 cm
3.46 kg ()
1 x Marvell ARMADA 385 1.33 GHz
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 6 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
8
RAM
512 MB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
12 TB
43.56 cm
29.13 cm
4.4 cm
3.46 kg ()
Processor / Memory
Processors Installed
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 6 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
8
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x eSATA 3Gb/s , 1 x management - DB-9
Built-in 3 cooling fans, LED indicator, Google Cloud Print, hardware encryption
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
25.8 Watt
Power Provided
100 Watt
Software Included
Synology Assistant, Synology Data Replicator 3
TAA Compliant
Limited warranty - 3 years
5 °C
50 °C
5 - 95%
Sound Emission
28.8 dBA
