Synology DS1517+ (2GB)/5TB-RED 5 Bay NAS
Quicklinx: CWFDWS00 Mfr#: DS1517+ (2GB)/5TB-RED
  • Atom
  • Quad-core 5-bay NAS with AES-NI support, with over 1,165 MB/s reading and 527 MB/s writing performance
  • PCIe slot for optional 10GbE add-on card. Four 1GbE (RJ-45) ports with failover and Link Aggregation support.
  • Optional M2D17 adapter card for dual M.2 SATA SSDs for cache
  • Two memory configurations: 2GB & 8GB with easily upgradable dual-channel design, up to 16GB
  • Advanced Btrfs file system offering 65,000 system-wide snapshots and 1,024 snapshots per shared folder
  • Scale up to 15 drives with two DX517 expansion units
Synology DiskStation DS1517+ features a quad-core processor with AES-NI hardware encryption engine, providing outstanding performance even with encryption. Supercharge your storage with the optional M.2 SSD adapter card for dual SSD cache drives. DS1517+ is the ideal storage solution for centralizing data backups, protecting critical assets, and sharing files across different platforms. Synology DS1517+ is backed with Synology’s 3-year limited warranty.
  • Next-generation file system for effective data protection
    The Btrfs file system introduces the most advanced storage technologies to prevent data corruption and reduce maintenance overhead with optimized snapshots. It ensures high-level data integrity, while taking advantage of flexible, efficient data protection and recovery tools.
  • Supercharge your storage with speedy performance
    Equipped with dual-channel memory and a PCIe slot, DS1517+ supports installing the dual M.2 SSD adapter card, M2D17, or the 10GbE NIC, for high-IOPS system cache and ultra-fast data transmission respectively.
  • Ultimate file management and sharing
    The web-based File Station is a user-friendly management tool built to allow intuitive, drag-and-drop operation without any complex setup required on your Mac or PC. The advanced search and filtering tools enable easy organization and sharing that entails just a link. Compatible with SMB, FTP, AFP, NFS, and WebDAV, File Station suits all environments.
  • Real-time collaboration on your private cloud
    Office is a collaboration package combining the convenience and usability of public clouds with the data privacy and security guaranteed by private clouds. It allows you to work seamlessly together on documents and spreadsheets in a protected environment.
  • Fully certified storage virtualization solutions
    Synology iSCSI storage fully supports most virtualization solutions to enhance work efficiency with easy management interface. VMware vSphere 6 and VAAI integration helps offload storage operations and optimizes computation efficiency. Windows Offloaded Data Transfer (ODX) speeds up data transfer and migration rate.
Synology Disk Station DS1517+ - NAS server - 5 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
5 TB
Max Supported Capacity
50 TB
5 (installed) / 5 (max)
25 cm x 24.3 cm x 16.6 cm
4.46 kg ()
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
5 x 1 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
5 TB
50 TB
25 cm
24.3 cm
16.6 cm
4.46 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
2 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
5 x 1 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, High Availability, video server, web server, backup server, file sharing, anti-malware protection, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, surveillance station, PXE support, Apple Time Machine compatible, cloud backup, VPN Server, SFTP client, anti-virus protection, DLNA support
Encryption Algorithm
SSL, TLS, AES-NI
DLNA CERTIFIED
Security DVR
40
Compression Format
MJPEG, H.264
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 x PCI Express 2.0 x8
4 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, hardware encryption, hot-swappable fans
Security Slot Type
Kensington security slot
FCC Class B certified, RoHS, BSMI Class B
Internal power supply
42.1 Watt
Power Consumption Stand by
23.1 Watt
Power Provided
200 Watt
Software Included
Drivers & Utilities, Synology Assistant
Limited warranty - 3 years
5 °C
5 - 95%
Sound Emission
26.2 dBA
