Add an RS232 DB9 or DB25 serial port to your laptop or desktop computer with this Plug-and-Play USB to Serial adapter cable.
The ICUSB232DB25 3-foot USB to RS232 Serial adapter cable lets you connect 9-pin (DB9) or 25-pin (DB25) RS232 serial devices to your laptop or desktop computer through a USB port, as though the computer offered an onboard serial port.
This high quality USB/RS232 Serial adapter cable is a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
- StarTech.com USB to Serial Adapter - 3 ft / 1m - with DB9 to DB25 Pin Adapter - Prolific PL-2303 - USB to RS232 Adapter Cable (ICUSB232DB25) - serial adapter - USB 2.0
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Grey
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Pocket PC 2000, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Mobile 6.0, Microsoft Windows Server 2012, Microsoft Windows 2000 / ME / XP, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Microsoft Windows CE 5.2
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wired
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x RS-232 - 25 pin D-Sub (DB-25)
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Grey
- OS Required
- Additional Requirements
- USB port
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 90%
