StarTech.com USB HDMI over Cat 5e Cat 6 KVM Console Extender - 1080p Uncompressed Video 330ft (100m)
Quicklinx: 95R5WS00 Mfr#: SV565UTPHDU
Type: Extender
£687.07 ex VAT
£824.48 inc VAT
Operate a PC from up to 100m away, with uncompressed 1080p HDMI video and USB keyboard / mouse.
The SV565UTPHDU USB HDMI KVM Extender lets you control a PC from up to 330ft (100m) away over a single Cat 5e or Cat 6 cable connection, with uncompressed 1080p HDMI video and access to up to 3 connected USB devices.
A flexible solution for powering large high-definition displays remotely, this HDMI USB extender supports uncompressed 1080p or 1920x1200 video resolutions at maximum distance. Additional features such as 3D and 4K support, HDCP, CEC and Lip Sync pass-through enable you to display your content exactly as you need it on the remote display.
This versatile KVM console extender can be connected to a single system, or cascaded to an existing KVM switch for remote operation of multiple systems, and features 3 USB 2.0 ports on the remote end, allowing you to connect a keyboard, mouse, printer or other peripherals. Since the extender uses Cat 5e (or better) network cable, you have the option to use existing infrastructure wiring, which helps avoid the hassle and expense of running bulky video cables.
StarTech.com 330ft (100m) USB HDMI over CAT5e / CAT6 KVM Extender - 1080p Uncompressed HD Video - IT Grade KVM Console Extender for PC (SV565UTPHDU) - KVM / USB extender
KVM / USB extender
External
Transmission Medium
CAT 5e/6
Max Transfer Distance
100 m
AC 120/230 V
17.8 cm x 11.2 cm x 3 cm
1.5 kg
P/N: SVA5M4NEUA
KVM / USB extender
External
Wired
Max Resolution
1080p
100 m
1 x HDMI female , 1 x USB - Type B male , 1 x USB 2.0 - Type A female , 1 x HDMI female , 2 x USB keyboard / USB mouse - Type A
FCC, RoHS
External power adapter
AC 120/230 V
17.8 cm
11.2 cm
3 cm
1.5 kg
20 - 80% (non-condensing)
P/N: SVA5M4NEUA
95R5 StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m In Stock £351.76
95R5 StarTech.com HDMI KVM Extender over LAN - 4K 30Hz In Stock £539.84
95R5 StarTech.com HDMI KVM Extender Over IP In Stock £265.32
95R5 StarTech.com HDMI Receiver Over IP In Stock £142.25
95R5 StarTech.com HDMI KVM Receiver Over IP In Stock £160.13
Type: Extender
Price Range Ex VAT: £500 - £750
