StarTech.com HDMI Receiver Over IP
Quicklinx: J7TXWS00 Mfr#: IH2006-HDMI-RX
£138.87 ex VAT
£166.64 inc VAT
The AVoIP HDMI Receiver extends a 4K 60Hz HDMI signal over an existing TCP/IP network when paired with a compatible transmitter, keeping systems secure from unauthorized access and physical damage. The plug-and-play design requires no drivers or software and is compatible with all major operating systems, including Windows, macOS, and Linux, as well as hardware platforms like Intel, AMD, Snapdragon/ARM, and Apple Silicon. Easily expand your setup by adding multiple receivers to create a one-to-many configuration, making it easy to scale with your business needs for flexible and future-proof IP Video or KVM distribution. Receiver features a durable metal housing with mounting kits for wall or under-desk installation, plus rubber feet for desktop stability. RS232 and 3.5mm audio passthrough ports enable serial and audio extension.
  • Driver-Free Installation
  • Scalable, Flexible, and Future-Proof
  • Professional-Grade Design
StarTech.com HDMI Receiver Over IP for the IH2006 Series, 4K 60Hz - video/audio extender - HDMI
Video/audio extender
External
Australia, Europe, New Zealand, North America, United Kingdom
HDMI
AC 100-240 V
External
Wired
HDMI
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Power, status
4K resolution support, steel housing, reset button
1 x RS-232 - terminal block , 1 x micro-USB (service) , 1 x audio line-out - mini jack female , 1 x Ethernet - RJ-45
Mounting kit, power adapter, RS-232 terminal block, rubber feet
RoHS, FCC, Plug and Play
External power adapter
AC 100-240 V
10 Watt
-20 °C
60 °C
0 - 90% RH (non-condensing)
J7TX StarTech.com HDMI KVM Extender Over IP In Stock £265.75
J7TX StarTech.com HDMI KVM Receiver Over IP In Stock £156.31
