The SV565DUTPU USB Dual VGA KVM Console Extender over CAT5 UTP lets you Operate a Dual VGA PC or KVM switch up to 650ft (200 m) away, as if it was installed locally, at high-definition 1920x1200 resolution. PC connection cables are included with this product for a ready to use solution.
The dual VGA cat5 KVM extender supports easy to use hot-key and push button commands which allow you to switch between local and remote connected systems, while console connections at both ends of your setup provide easy access to all connected systems from either location. The hot-key commands also provide video adjustment controls for optimizing picture quality over varying distances. Extending over two standard Cat 5 (or better) cables gives you the ability to use existing infrastructure wiring to achieve remote access to your server or KVM switch.
- StarTech.com 650 ft/200m USB 2.0 Dual VGA KVM Console Extender over Cat5 UTP -for Dual VGA, USB-enabled PC or KVM Switch - Upto 1920x1200 (SV565DUTPU) - KVM extender
- KVM extender
- Form Factor
- External
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 200 m
- Power
- AC 120/230 V
- 8 cm x 15.5 cm x 4 cm
- 0.54 kg
- 3-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- KVM extender
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1200
- 200 m
- 2 x USB - Type A , 2 x VGA - HD-15
- Cables Included
- 2 x keyboard / mouse / video / USB cable - 1.8 m
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 8 cm
- 15.5 cm
- 4 cm
- 0.54 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £10.69 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.21 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
StarTech.com HDMI KVM Extender over LAN - 4K 30Hz | In Stock | £525.34 |
