StarTech.com USB-C to VGA Adapter
Quicklinx: BJWTWS00 Mfr#: CDP2VGA
More than 50 in stock
£24.21 ex VAT
£29.05 inc VAT
Connect your MacBook, Chromebook or laptop with USB Type-C to a VGA monitor or projector. This USB-C to VGA video adapter lets you output high-definition VGA video from your USB Type-C device.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. The connector is featured on ultra-portable devices with USB 3.1 Gen 1. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design, which makes it the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always work, saving you the hassle and embarrassment of struggling with your device when you're trying to present.
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your USB Type-C connection to deliver every detail in stunning high-definition.
Note: Your USB-C equipped device must support video to work with this adapter. The adapter will not output digitally encrypted content.
StarTech.com USB-C to VGA Adapter - Black - 1080p - Video Converter For Your MacBook Pro - USB C to VGA Display Dongle (CDP2VGA) - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA
Enclosure Colour
3-year warranty
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Bus Type
USB-C
Max Resolution
1920 x 1200
VGA
USB powered
FCC, RoHS
Enclosure Colour
Limited warranty - 3 years
Price Range Ex VAT: 0 - 50
