Use this cable to connect your USB Type-C computer directly to a Mini DisplayPort monitor, without additional adapters. This USB-C to Mini DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your Mini DP monitor. The adapter offers a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For longer installations, StarTech.com also offers a 1.8 m (6 ft.) USB-C to Mini DisplayPort cable (CDP2MDPMM6B), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
High-resolution support
This cable supports a maximum output resolution of 3840 x 2160, allowing for crisp and clear visuals suitable for high-definition displays. -
Broad compatibility
Designed to be compatible with USB 3.1 and Thunderbolt 3 standards, this cable provides flexibility in connecting various devices. -
Audio enhancement
The cable supports 5.1 audio channels, ensuring sound to accompany your visual content for an engaging viewing experience. -
Alternate mode functionality
With DisplayPort Alternate Mode support, this cable allows USB-C devices to connect to Mini DisplayPort displays, expanding your connectivity options. -
Robust design
The construction of this cable ensures reliability and performance, making it suitable for everyday use in various environments.
 - StarTech.com 1m / 3.3ft USB-C to Mini DisplayPort Cable - 4K 60Hz - Black - USB 3.1 Type C to mDP Adapter (CDP2MDPMM1MB) - video adapter cable - 24 pin USB-C to Mini DisplayPort - 1 m
 - Video adapter cable
 - 4K60Hz (3840 x 2160) support, DisplayPort Alternate Mode support, 5.1 audio channel support
- Length
 - 1 m
- Connector
 - 24 pin USB-C - male (input)
- Connector (Second End)
 - Mini DisplayPort - male (output)
 - USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
 - Black
 - 3-year warranty
- Length
 - 1 m
 - Black
 - 25 g
- Connector
 - USB 3.1 / Thunderbolt 3 / DisplayPort 1.2, FCC, RoHS
- Shipping Width
 - 20 cm
- Shipping Depth
 - 22 cm
- Shipping Height
 - 1.2 cm
- Shipping Weight
 - 30.5 g
 - 3-year warranty
                        StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £17.91 |
                        StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.69 |
                        StarTech.com 1m USB-C to HDMI Cable | In Stock | £25.04 |
                        StarTech.com 1m USB-C to VGA Cable | In Stock | £19.38 |
                        StarTech.com 2m USB-C to VGA Cable | In Stock | £20.80 |
                        StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £19.74 |
