This USB-C to Mini DisplayPort adapter enables you to output mDP video and audio from the USB Type-C port on your laptop, tablet, smartphone or other USB C device.
Extended Cable Length
This USB C adapter dongle is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands. -
Ultra HD 4K Resolution
The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable. Plus, the USB-C to Mini DP adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications. -
Ultimate Portability
This USB C to mDP video converter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag while commuting between your home, office or traveling for business. The CDP2MDPEC is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes: • Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter
- StarTech.com USB C to Mini DisplayPort Adapter, 4K 60Hz USB-C to mDP Adapter Dongle, USB Type-C to Mini DP Monitor/Display, Video Converter, Works w/ Thunderbolt 3, 12" Long Attached Cable - DP Alt Mode, mDP 1.2 (CDP2MDPEC) - DisplayPort adapter - 24 pin USB-C to Mini DisplayPort - 30.6 cm
- 4K60Hz (3840 x 2160) support, plastic housing, HBR2 support, DisplayPort Alternate Mode support
- Length
- 30.6 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Mini DisplayPort - female
- Displayport 1.2/Thunderbolt 3
- Grey
- 3-year warranty
- Length
- 30.6 cm
- Grey
- 2.7 cm
- 1.6 cm
- 28 g
- Connector
- Displayport 1.2/Thunderbolt 3, FCC, RoHS, HDCP 2.2, HDCP 1.4
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.8 cm
- Shipping Weight
- 31 g
- 3-year warranty
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.27 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.62 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £13.06 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £21.97 |
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £16.39 |
StarTech.com USB C to VGA Adapter 1080p | In Stock | £21.51 |
