StarTech.com USB-C to VGA Adapter
Quicklinx: BJWTWS00 Mfr#: CDP2VGA
10 In Stock
£22.16 ex VAT
£26.59 inc VAT
Connect your MacBook, Chromebook or laptop with USB Type-C to a VGA monitor or projector. This USB-C to VGA video adapter lets you output high-definition VGA video from your USB Type-C device.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. The connector is featured on ultra-portable devices with USB 3.1 Gen 1. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design, which makes it the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always work, saving you the hassle and embarrassment of struggling with your device when you're trying to present.
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your USB Type-C connection to deliver every detail in stunning high-definition.
Note: Your USB-C equipped device must support video to work with this adapter. The adapter will not output digitally encrypted content.
  • Versatile connectivity
    This adapter enables connections from USB-C devices to VGA displays, accommodating a wide range of devices and setups.
  • High resolution support
    Offering a maximum output resolution of 1920 x 1200, this adapter ensures optimal display quality for any application.
  • Compact design
    The lightweight and portable design of the adapter makes it easy to carry and perfect for on-the-go use.
  • Easy plug and play
    Simply connect the USB-C adapter to your device and VGA display to begin using without complicated setup.
  • Reliable compliance
    This product meets FCC and RoHS standards, ensuring safety and environmental suitability.
StarTech.com USB-C to VGA Adapter - Black - 1080p - Video Converter For Your MacBook Pro - USB C to VGA Display Dongle (CDP2VGA) - USB / VGA adapter - 24 pin USB-C to HD-15 (VGA) - 18 cm
USB / VGA adapter
USB power, 1920 x 1200 (WUXGA) support, DisplayPort Alternate Mode support
Length
18 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - female (output)
USB 3.1 Gen 1 / Thunderbolt 3
3-year warranty
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB4CDOCK
USB / VGA adapter
Length
18 cm
3.7 cm
1.4 cm
24 g
Connector
USB 3.1 Gen 1 / Thunderbolt 3, FCC, RoHS
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
1.7 cm
Shipping Weight
29 g
3-year warranty
BJWT StarTech.com USB-C to HDMI Adapter In Stock £15.52
BJWT StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
BJWT StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.73
BJWT StarTech.com 2m USB-C to DVI Cable In Stock £23.46
BJWT StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
BJWT StarTech.com 1m USB-C to DVI Cable In Stock £11.22
BJWT StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.30
BJWT StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
BJWT StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
BJWT StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
BJWT StarTech.com USB-C to HDMI Presentation In Stock £14.13
BJWT StarTech.com USB-C to DisplayPort Adapter In Stock £20.19
BJWT StarTech.com USB-C to DVI with USB PD In Stock £10.14
BJWT StarTech.com 6 ft USB C to DP Cable - White In Stock £9.11
BJWT StarTech.com 2m USB C to HDMI Cable - Black In Stock £28.04
BJWT StarTech.com 1m USB C to HDMI Cable - Black In Stock £28.42
BJWT StarTech.com 3m USB C to DisplayPort Cable - White In Stock £20.18
BJWT StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £26.32
BJWT StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.08
BJWT StarTech.com 1m USB C to HDMI Cable - White In Stock £22.55
BJWT StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £9.72
BJWT StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.26
BJWT StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
BJWT StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
BJWT StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
BJWT StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
BJWT StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
BJWT StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.97
BJWT StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.47
BJWT StarTech.com USB C to DP Adapter - 8K/4K In Stock £13.33
BJWT StarTech.com USB C to mDP Adapter 12" Cable In Stock £14.97
BJWT StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
