StarTech.com USB-C to HDMI Adapter
Quicklinx: BTM3WS00 Mfr#: CDP2HD
More than 50 In Stock
£19.04 ex VAT
£22.84 inc VAT
Connect your MacBook, Chromebook or laptop with USB-C to an HDMI display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device such as a MacBook or Chromebook laptop. This adapter works with USB-C devices that pass a DisplayPort video signal. It's also compatible with Thunderbolt 3 ports.
This USB type-C video adapter is highly portable with a small footprint and lightweight design. The adapter is the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of fiddling with your device when you're trying to deliver a presentation.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Note: Your USB-C equipped device must support video to work with this adapter.
  • Enjoy High-Definition Resolution up to 4K at 30Hz
    This adapter lets you harness the video capabilities from your computer's USB-C connection, to deliver the astonishing quality of UHD to a 4K 30Hz display. You can achieve an output resolution of up to 3840 x 2160p at 30Hz, perfect for performing high-resolution tasks. Plus, the USB-C display adapter is backward compatible with 1080p monitors and displays, making it a great accessory for any workspace application.
  • Hassle-Free Connection to Your USB Type-C Laptop
    This HDMI converter lets you use the versatile USB Type-C port on your portable device. USB-C is a reversible connector, so you can plug it to your device in any direction. Plus, it's Thunderbolt 3 compatible, providing a hassle-free connection to your Windows or Mac based Thunderbolt 3 computer.
  • Lightweight Design Makes it the Perfect Travel Companion
    This compact, lightweight USB-C video adapter is easy to carry in your laptop bag. It's ideal for BYOD (Bring Your Own Device) applications at the office and is compatible with any device that supports USB-C DP Alt Mode. CDP2HD is backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com USB C to HDMI Adapter - USB 3.1 Type C Converter - 4K 30Hz UHD - adapter - HDMI / USB - 14.7 cm
Cable
Adapter - HDMI / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Length
14.7 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
HDMI - female (output)
Thunderbolt 3
4K30Hz (3840 x 2160) support
3-year warranty
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB3DK2DPM2, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DOCK2DPPD, TB3DOCK2DPPU
Cable Type
Adapter 4K30Hz (3840 x 2160) support
Interface Supported
HDMI / USB
Jacket Material
Plastic
Thunderbolt 3
Length
14.7 cm
DisplayPort Alternate Mode support, 7.1 PCM audio channel support
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Connector
19 pin HDMI Type A - female (output)
FCC, RoHS, WEEE, REACH, RCM
2.3 cm
0.9 cm
22 g
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1 cm
Shipping Weight
30 kg
Limited warranty - 3 years
BTM3 StarTech.com USB-C to HDMI Adapter In Stock £17.39
BTM3 StarTech.com USB-C to HDMI Adapter In Stock £19.04
BTM3 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.75
BTM3 StarTech.com 2m USB-C to DVI Cable In Stock £23.49
BTM3 StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
BTM3 StarTech.com 1m USB-C to DVI Cable In Stock £11.23
BTM3 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £17.36
BTM3 StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
BTM3 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
BTM3 StarTech.com USB-C to DisplayPort Adapter In Stock £22.62
BTM3 StarTech.com USB-C to HDMI Presentation In Stock £13.64
BTM3 StarTech.com USB-C to DisplayPort Adapter In Stock £20.19
BTM3 StarTech.com 6 ft USB C to DP Cable - White In Stock £9.79
BTM3 StarTech.com 2m USB C to HDMI Cable - Black In Stock £28.08
BTM3 StarTech.com 1m USB C to HDMI Cable - Black In Stock £28.47
BTM3 StarTech.com 3m USB C to DisplayPort Cable - White In Stock £20.18
BTM3 StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £26.32
BTM3 StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.13
BTM3 StarTech.com 1m USB C to HDMI Cable - White In Stock £22.55
BTM3 StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £10.47
BTM3 StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.26
BTM3 StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.10
BTM3 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.59
BTM3 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
BTM3 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £20.49
BTM3 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £12.11
BTM3 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.68
BTM3 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £17.48
BTM3 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.47
BTM3 StarTech.com USB C to DP Adapter - 8K/4K In Stock £14.24
BTM3 StarTech.com USB C to mDP Adapter 12" Cable In Stock £14.78
BTM3 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
