Use this USB-C to DP cable to connect your USB Type C computer directly to a monitor, without additional adapters. This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DP monitor or projector. The adapter offers a connection distance of up to 3 m (10 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
While this white adapter looks great next to computers that match the look and feel of laptops like your MacBook or HP Envy, it works with any USB-C computer that supports DisplayPort. At 3 m (10 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy and professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to DisplayPort cable (CDP2DPMM1MW) and 1.8 m (6 ft.) USB-C to DisplayPort cable (CDP2DPMM6W), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
- StarTech.com 9.8ft/3m USB C to DisplayPort 1.2 Cable 4K 60Hz, USB-C to DisplayPort Adapter Cable HBR2, USB Type-C DP Alt Mode to DP Monitor Video Cable, Compatible w/ Thunderbolt 3, White - USB-C Male to DP Male (CDP2DPMM3MW) - external video adapter - STM32F072CBU6 - white
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- STM32F072CBU6
- Max Resolution
- 3840 x 2160
- Interfaces Details
- DisplayPort (male connector)
- 2 cm 1 cm
- Length
- 3 m
- Enclosure Colour
- White
- 3-year warranty
- Bus Type
- USB-C
- Graphics Engine
- STM32F072CBU6
- Max Resolution
- 3840 x 2160 at 60 Hz
- HD/4k Ready, Thunderbolt 3 compatible, 7.1 channel surround sound ready
- FCC, RoHS, WEEE
- 2 cm
- 1 cm
- Length
- 3 m
- 180 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 70%
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £13.19 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.69 |
StarTech.com 1m USB-C to HDMI Cable | In Stock | £25.04 |
StarTech.com 1m USB-C to VGA Cable | In Stock | £19.38 |
StarTech.com 2m USB-C to VGA Cable | In Stock | £20.80 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £19.74 |
StarTech.com 3m USB C to DisplayPort Cable - Black | In Stock | £20.00 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £19.75 |
