Connect your MacBook, Chromebook or laptop with USB-C to an HDMI display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device such as a MacBook or Chromebook laptop. This adapter works with USB-C devices that pass a DisplayPort video signal. It's also compatible with Thunderbolt 3 ports.
This USB type-C video adapter is highly portable with a small footprint and lightweight design. The adapter is the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of fiddling with your device when you're trying to deliver a presentation.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Note: Your USB-C equipped device must support video to work with this adapter.
Enjoy High-Definition Resolution up to 4K at 30Hz
This adapter lets you harness the video capabilities from your computer's USB-C connection, to deliver the astonishing quality of UHD to a 4K 30Hz display. You can achieve an output resolution of up to 3840 x 2160p at 30Hz, perfect for performing high-resolution tasks. Plus, the USB-C display adapter is backward compatible with 1080p monitors and displays, making it a great accessory for any workspace application. -
Hassle-Free Connection to Your USB Type-C Laptop
This HDMI converter lets you use the versatile USB Type-C port on your portable device. USB-C is a reversible connector, so you can plug it to your device in any direction. Plus, it's Thunderbolt 3 compatible, providing a hassle-free connection to your Windows or Mac based Thunderbolt 3 computer. -
Lightweight Design Makes it the Perfect Travel Companion
This compact, lightweight USB-C video adapter is easy to carry in your laptop bag. It's ideal for BYOD (Bring Your Own Device) applications at the office and is compatible with any device that supports USB-C DP Alt Mode. CDP2HD is backed by a 2-year StarTech.com warranty and free lifetime technical support.
- StarTech.com USB C to HDMI Adapter - USB 3.1 Type C Converter - 4K 30Hz UHD - adapter - HDMI / USB - 14.7 cm
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Length
- 14.7 cm
- Black
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- HDMI - female (output)
- Thunderbolt 3
- 4K30Hz (3840 x 2160) support
- 3-year warranty
- Designed For
- P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C, TB3DK2DPM2, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DOCK2DPPD, TB3DOCK2DPPU
- Cable Type
- Adapter 4K30Hz (3840 x 2160) support
- Interface Supported
- HDMI / USB
- Jacket Material
- Plastic
- Thunderbolt 3
- Length
- 14.7 cm
- DisplayPort Alternate Mode support, 7.1 PCM audio channel support
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- Connector
- 19 pin HDMI Type A - female (output)
- FCC, RoHS, WEEE, REACH, RCM
- 2.3 cm
- 0.9 cm
- 22 g
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 30 kg
- Limited warranty - 3 years
- Designed For
StarTech.com USB-C to HDMI Adapter | In Stock | £15.93 |
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £7.64 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £18.72 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £23.46 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.94 |
StarTech.com 1m USB-C to DVI Cable | In Stock | £11.22 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £16.30 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £23.48 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com USB-C to HDMI Presentation | In Stock | £14.13 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £20.19 |
StarTech.com 6 ft USB C to DP Cable - White | In Stock | £9.11 |
StarTech.com 2m USB C to HDMI Cable - Black | In Stock | £28.04 |
StarTech.com 1m USB C to HDMI Cable - Black | In Stock | £28.42 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £20.18 |
StarTech.com 3m USB C to DisplayPort Cable - Black | In Stock | £26.32 |
StarTech.com 3m USB C to HDMI Cable - Black | In Stock | £28.08 |
StarTech.com 1m USB C to HDMI Cable - White | In Stock | £22.55 |
StarTech.com 1.8m 6 ft USB C to mDP Cable | In Stock | £9.71 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £20.26 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.36 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.04 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £23.05 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £19.80 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £11.44 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.89 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.97 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £16.65 |
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £13.33 |
StarTech.com USB C to mDP Adapter 12" Cable | In Stock | £14.97 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.49 |
StarTech.com 6.6ft USB C to DP 1.2 Cable | In Stock | £31.29 |
